04-12-2017, 09:14 AM | #21 |
| Re: Knuckle weights and steering links
Man, you make some crazy cool stuff Ernie! Do those knuckles just use XR/Wraith shims? Looks like youre running FBA shafts too? If so, what length? Those Ascender axles just use a Axial inner tang? |
04-12-2017, 10:14 AM | #22 | |
I wanna be Dave Join Date: Apr 2010 Location: Oakridge
| Re: Knuckle weights and steering links Quote:
Ernie Last edited by CODYBOY; 04-12-2017 at 10:17 AM. | |
04-13-2017, 06:26 AM | #23 |
Awesome. Thanks for the info. I am sure you already know this and just like to do things the correct way but you dont have to run the chub bearing. There are lots of cars I have made shafts for or tubes for and I simply eliminate them. |
04-13-2017, 09:13 AM | #24 | |
Thanks Ernie | |
04-18-2017, 11:56 AM | #25 |
Nice parts and great work! Erik, eliminate which c-hub bearing?
04-18-2017, 04:52 PM | #26 |
I wanna be Dave Join Date: Apr 2015 Location: Roseville, Ca
Pretty sure he's talking about the bearing at the end of the housing/chub. All you need are the two bearings inside the knuckle.
04-18-2017, 08:20 PM | #27 |
That makes more sense, thanks.
04-19-2017, 08:18 AM | #28 |
Yep, the bearing that goes on the inner shaft.
04-30-2017, 01:25 AM | #29 |
Newbie Join Date: Feb 2017 Location: Richmond
on a bad note my losi ones ran 30 min to a hour inner bearing came lose hope dlux will fix
04-30-2017, 08:58 AM | #30 |
| Re: Knuckle weights and steering links |
05-01-2017, 09:13 AM | #31 | |
On the LCC knuckles, there just isnt much engagement on the bearing. I dont know anybody else that has had the problem but wouldnt be surprised if it happened to most eventually. Simple fix though. On another note, if you ever have an issue or question, you can always send me a message or email. Addressing problems in public might go missed as I am not guaranteed to see them. | |
05-01-2017, 07:52 PM | #32 |
sorry new to all of this email text pms and forum wish to talk to you in st of hunt and peck i also run a bis i under stand about the phone calls please call me 606 9752094 should not the bearing have half thou press fit looks like there is more than enongh room for more materal to br added at lease by my mic
05-01-2017, 11:58 PM | #33 |
Knuckle weights and steering links - Similar Threads | ||||
Knuckle Weights vs. Wheel Weights | Harvo | Tires and Wheels | 34 | 11-16-2011 01:15 PM |
