Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Team Losi Comp Crawler
Thread: LCC build suggestions
Old 10-24-2016, 06:34 PM   #1
Default LCC build suggestions
Building my 1st crawler and picked up an lcc roller. Thinking of picking up parts below to get it running. Any suggestions would be greatly appreciated. Thanks
Mamba Max Pro
Castle BEC - do i need this since the MMP has an integrated BEC?
17.5 or 21.5t motor - which would you prefer and why?
Pinion - what would you suggest for 17.5 & 21.5 motor
Hitec 7950 servo
TX/RX - i have a futaba 2 ch that i want to use for now to get started then in the future will be getting a 3 ch to use the DIG
vince.j.samson is offline   Reply With Quote
Old 10-25-2016, 05:36 AM   #2
Default Re: LCC build suggestions
I prefer a 13.5T motor for the wheel speed. Everything else looks good.
rob5059 is offline   Reply With Quote
Old 10-25-2016, 05:49 AM   #3
Custom Carbon Fiber
Robbob's Avatar
I ran a 17.5 in mine years ago with a 12 tooth pinion (if memory is correct) and ran 3S packs (850mah)
13.5 would def give more wheel speed and is probably a better fit these days with equipment and batteries.
BEC yes - You want the servo to get strong voltage when the motor is pulling down on the battery.
If you arent stuck on the mamba max esc I would recommend the Tekin RS - its a smaller footprint and can still run 3S. Its programmable also with Tekins Hotwire.
Futaba 3PMX radio has a third channel switch on it and should be easy to find and relatively cheaper then the MT4 and higher end Futabas. But any 2 Channel is good. Plus if you dont use dig then you can run against of shaft trucks in the 2.2S class.
Going up against modern day MOA's if a tough task for shafties, it can be done and has been done and sure is fun to see them win.
Robbob is offline   Reply With Quote
Old 10-25-2016, 07:07 AM   #4
Thank you guys
LCC build suggestions - Similar Threads
build suggestions scx10mudder Axial SCX-10 2 10-23-2011 07:39 PM
My Build... Suggestions? BluFalcon Axial AX-10 Scorpion 6 01-17-2011 09:21 PM
New LCC to build - Advise/suggestions welcome wags Team Losi Comp Crawler 5 05-13-2010 11:59 AM
RcBros LCC Build, Hi-Res pics & More Build!! RcBro Team Losi Comp Crawler 30 06-03-2009 07:26 PM
First build suggestions?? golfingguy27 General Crawlers 0 06-22-2008 01:05 AM
