06-20-2017, 10:54 PM | #261 |
I wanna be Dave Join Date: Apr 2010 Location: Oakridge
| Re: Losi Steering mod design |
12-21-2017, 08:28 PM | #262 |
12-26-2017, 09:27 PM | #263 |
Pebble Pounder Join Date: Oct 2012 Location: Plattsmouth
I’m interested in a couple kits xr width and I’m still running a couple Losi crawlers for fun!
12-27-2017, 08:45 PM | #264 |
PM sent.
12-30-2017, 07:34 PM | #265 |
OK H2Ohaze, I sent you the info about XR steering mod, thanks for asking. Ernie |
12-30-2017, 07:47 PM | #266 |
Here is a little update on the Axle mod. The reason for the mod is to add more steering to your crawler. It is also called the XR mod because we use Axial XR10 universals, C-hubs and knuckles to achieve almost 65 degrees of steering, 20 more than the stock steering. The service I provide is making and machining parts to build a kit for the modification. Here are a few photos of the kit and how it would look after you install your parts. The brass trumpets I make for the mod. How it will look when you install your stock parts and the axial parts with mine. A shot of the improved steering you will get with mod. A shot of my Losi with one of the axles installed. Any questions, just PM me. Ernie |
01-05-2018, 11:13 PM | #267 |
OK huskerfan406, your axles are headed your way! Ernie |
01-06-2018, 12:20 AM | #268 |
01-12-2018, 11:32 PM | #269 |
| Re: Losi Steering mod design Axles showed up a couple days ago! I have mocked up in in the machine! I'm happy with the way it looks! Thanks
01-13-2018, 12:37 PM | #270 |
01-25-2018, 11:46 AM | #271 |
Newbie Join Date: Jun 2017 Location: Hendersonville
Codyboy do you still have the parts to make these axles? If so I am interested Thanks Todd |
01-30-2018, 06:39 PM | #272 |
Newbie Join Date: Aug 2006 Location: Leesburg, Fl.
Codyboy, are you still offering these axle sets ? If so how complete and of course how much ? Steve |
01-30-2018, 07:22 PM | #273 | |
| Re: Losi Steering mod design Quote:
Here is a little update on the Axle mod. The reason for the mod is to add more steering to your crawler. It is also called the XR mod because we use Axial XR10 universals, C-hubs and knuckles to achieve almost 65 degrees of steering, 20 more than the stock steering. The service I provide is making and machining parts to build a kit for the modification. Here are a few photos of the kit and how it would look after you install your parts. I can't mention prices in this thread, so I will send you a PM with cost. Ernie | |
02-10-2018, 11:05 AM | #274 |
Quarry Creeper Join Date: Mar 2009 Location: Phoenix
WOW! What a great thread to read thru after yet another hiatus from the scene...pm sent codyboy! Thank you!
02-10-2018, 12:28 PM | #275 |
what class would this put you in, in the competitions? would this mod still allow one to run the lcc in its true sport/shafty class? axle width?
02-13-2018, 05:13 AM | #276 |
Quarry Creeper Join Date: Jan 2018 Location: East brady
They are very nice Ernie thank you .very nice workmanship! Once i get my safety silv I’ll link a pic of my project.
02-15-2018, 09:59 AM | #277 |
Newbie Join Date: Mar 2016 Location: Oregon & NorCal
Wow sir you do some really cool stuff! I have been reading through your threads all morning and you have just blown my mind! I went to send you a pm and I was shocked to see you are right up the road from me! I am just south of eugene, lol what a small world! I have a set of these axles and I am playing around with some ascender axles as well, I would love to pick your brain later if you have some time! Thanks for the great reads and awesome knowledge!
02-15-2018, 11:19 AM | #278 | |
Ernie | |
02-24-2018, 04:10 PM | #279 |
Newbie Join Date: Nov 2017 Location: Colorado
Just got my steering mod in. Ernie built me up with C-hubs, Dlux Knuckleweights ,better servo, links, KrazedBuilds CF axle-battery plate, everything needed to just plug and play!!! I plugged in the servo with my Tx/Rx, and it centered axle first try. It will be over a week before I can install and reset endpoints on my LNC, but everything is looking topnotch, and more than that, my experience has been that Ernie didn't mind all my newbie questions, was more than willing to work with me, did all the assembly except the obvious final install on my LNC. He is using the new design that does not use zipties but glue. |
04-03-2018, 06:29 PM | #280 |
It has been a while since I post up some new info on my axle upgrade, so here is a little update. This is the 3rd complete axle build I've done in the month, so thought I'd post up some photos. These are going to Canada, thanks Vince!! I'm also getting more requests for rear axles that are the same width as the fronts with the wide XR build. So guess I will start offering these also. All Losi axle builds are by order only. This set has the Dlux front weighted knuckle. Thanks for looking, Ernie |
Losi Steering mod design - Similar Threads | ||||
Losi MRC steering mod | fshnut007 | Losi Mini-Rock Crawler | 9 | 08-30-2017 03:33 PM |
What is the steering mod from Losi to Axial xr / Wraith knuckles called? | Pennington Research | Team Losi Comp Crawler | 7 | 02-08-2015 07:27 PM |
Xirtic + JP High Clearance Steering Mod on Mod | JeffK11 | RC4WD Bully | 1 | 02-01-2012 09:55 AM |
Front Dig Mod,steering mod & pushbar | TheButcher69 | General Crawlers | 1 | 11-06-2006 06:32 PM |
