04-08-2018, 10:04 AM | #101 | |
Quarry Creeper Join Date: Jan 2018 Location: East brady
| Re: Where do I go from here? Quote:
Ya it’s quite a bit higher than the sheet aluminum template. I also mounted it to the top of the plate . That gives me an extra 1/8 inch or so. | |
04-08-2018, 10:24 AM | #102 |
This is just a few pics. I don’t want to post them all. The one with the black battery is a full size 5500 mah 3s battery I just put it on there to show how much room is there now. I could redesign it and move the servo over a few more mm and comfortably fit a full hard pack on the axle. I still need to finish it but want to try it out b4 I go threw the process of all of that lol.
04-14-2018, 12:37 PM | #103 |
Well it’s a fail it works but it puts the pull to the wrong side. Left on the wheel is right on the truck. So I went back to the krazed builds plate . I’m gonna try something with it I guess
04-14-2018, 12:48 PM | #104 |
Quarry Creeper Join Date: Nov 2008 Location: grand junction
You should be able to reverse your steering channel on your transmitter to fix that Sent from my SM-G930V using Tapatalk |
04-14-2018, 01:25 PM | #105 |
And I got the aluminum trany output housing and my 16t TLR pinion today. Got it all in and mounted and I used the krazed builds rc plate on the inside of the chassis. I drilled and tapped the holes an put a nut on them to hold it secure.
04-14-2018, 01:30 PM | #106 | |
*Update* Well after you said that and I replied all stupid like , I then decided to read the owners manual and you are absolutely correct. I was so hell bent on the radio being a P.O.S. that I overlooked the switches on top of it. It seems that I can reverse both,... thank you mikero! Last edited by Rattzo1; 04-15-2018 at 08:57 AM. | |
04-14-2018, 01:53 PM | #107 |
So I finish up installing the krazed plat and servo. Extend my steering arm and now I have an issue, can one of you rc vets help me out? It seems when I turn to the right that it don’t turn the whole way. But to the left it hits the stops. And when not steering it goes straight. Why won’t it turn the whole way on the servo side?
04-14-2018, 06:33 PM | #108 | |
Pebble Pounder Join Date: Mar 2016 Location: Harrisburg/York
Did you check your travel limits. I have a dx4c and I can go and adjust the limits. Example turn that side up higher. Sent from my iPhone using Tapatalk | |
04-15-2018, 12:30 AM | #109 | |
But I was kind of thinking on those same lines just mechanically. Would it be better to run the steering link to the long side? Maybe the angle is too steep? Or should I try a longer servo arm to drop it down a little bit? I’m kind of baffled so let me know your thoughts. I’ll try whatever. | |
04-15-2018, 07:23 AM | #110 | |
Did you try moving the servo arm a few teeth one way or the other? Sent from my iPhone using Tapatalk | |
04-15-2018, 08:14 AM | #111 |
Yes. I centered it by turning it on I took the screw out of the arm then took the shaft apart and added one blue shim then remounted the servo arm. Got like two teeth out of it. It helped a little but just a little
04-15-2018, 08:46 AM | #112 |
Pebble Pounder Join Date: Dec 2011 Location: Ridgecrest, CA
| Re: Where do I go from here? |
04-15-2018, 09:01 AM | #113 |
| Re: Where do I go from here? It does I just apologized to mikero and thanked him as I thank you. Like I said to him I was so hell bent on it being a P.O.S. I overlooked the switches on top. It can reverse both.
04-15-2018, 09:09 AM | #114 |
Well I made a long arm to go across the axle recentered the servo and mounted the arm . Now the pull is even. I don’t know why it wouldn’t throw the whole way with the short one .other than it was too sharp of an angle or some stuff like that. So I’m going to try it out like it is till I break it . Then I’ll put my plate on and give it a try.
04-20-2018, 03:59 PM | #115 |
So what’s everyone’s trick for keeping the pins and shafts in the drive shafts
04-20-2018, 04:47 PM | #116 |
Blue loctite good Allen drivers and some heat shrink tubing just in case Sent from my SM-G930V using Tapatalk |
04-20-2018, 05:07 PM | #117 |
Rock Stacker Join Date: Oct 2013 Location: Great Britain
I broke my first pin the other day,the pack I replaced it with included the spring retainers. Sent from my BLN-L21 using Tapatalk |
04-20-2018, 05:14 PM | #118 |
The V3 front axle cv's have the spring retainer provisions machined in the old ones don't neither do the drive shafts for the lcc, not sure how the night crawler shafts are know they're some kind of dog bone. I was lucky enough to get chromoly pins from dlux back in the day never broke one Sent from my SM-G930V using Tapatalk |
04-20-2018, 05:26 PM | #119 |
Well I have springs on the v1 and v2 and they are secure so far Sent from my BLN-L21 using Tapatalk |
04-20-2018, 06:53 PM | #120 |
It’s a dog bone style with a barrel and a pin through the end on the axle end and the dog bone end to the trany. No slots for a retainer spring or anything. That’s a generic pic from the net, it is however what is in the LNC2.0 . Is there a upgrade or downgrade that can be done to help this problem? Or do I need to fab something ? I think I’ll try the shrink tube but I think something better can be made for this joint. Thank you guys
