Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Team Losi Comp Crawler
Thread: Upgrades to my stock v1 Night crawler ?
Old 01-04-2022, 01:50 PM   #1
Default Upgrades to my stock v1 Night crawler ?
Hey guys . So bought my losi NC in 2010 when I was 20 . I played with it a few times and honestly sat it on the shelf and haven't touched it in 10 years. I just decided to get back into it now that all my time for fullsize jeeps and traveling is limited ,and the fact that there is a crawler park down the street from my house ( harford rocks) . What are some good general mods to make to my losi ? I'm guessing weighting down the front wheels and maybe better tires than the factory ones ? Anything else I should be looking into? Thanks
Jd70crawler is offline   Reply With Quote
Old 01-05-2022, 04:27 AM   #2
rob5059's Avatar
Default Re: Upgrades to my stock v1 Night crawler ?
Since you have a V1 NC, you have 21t gears in your axles. I would pickup a set of the HD worm gears which are 25t and install them in the rear axle. This will overdrive the front axle and give you a spare set of 21t gears which are hard to find.
Grease your axles.
Next thing would be tires. I would go to the crawl park and see what other people are running. I am sure your 10 year old tires are hard and have flat spots. If you are keeping the stock rims, I would add a little weight in the front ones. Now the fun begins, everyone is going to bitch since I said to add rotational weight.
Battery placement and size is the next thing. BWD RC makes a front axle battery plate. Stock electronics support a 2 cell Lipo. I do not remember if it has a low voltage disconnect built in. For crawling small 600 to 850ma battery pack.
This should start you down the rabbit hole or put it back on the shelf for another 10 years.
Electronics would be the next upgrade. The NC works great on a brushless esc and motor. 13.5T motor with a 14T pinion gear and a 3cell battery work great.
rob5059 is offline   Reply With Quote
Old 04-02-2022, 12:55 PM   #3
If you have a 3d printer or have access to one i would highly recomend this upgrade
https://www.thingiverse.com/thing:4646632
Nkop63 is offline   Reply With Quote
Old 08-29-2022, 04:21 AM   #4
rob5059's Avatar
Sorry for the mix up. HD gears are 21T. 25T was the LCC and gen1 LNC
This is the part number you are looking for.
LOSA3187
Upgrades to my stock v1 Night crawler ? - Similar Threads
Losi night crawler upgrades Lounorris88 Team Losi Comp Crawler 2 05-21-2021 10:41 AM
Losi Night Crawler Upgrades? murlin12 Newbie General 14 11-03-2013 08:50 PM
Losi Night Crawler Upgrades? murlin12 General Crawlers 2 10-30-2013 09:13 AM
Night Crawler Upgrades goodvibessa Team Losi Comp Crawler 11 02-28-2011 02:45 PM
Night Crawler upgrades. jhr513 Team Losi Comp Crawler 63 07-15-2010 07:38 PM
Copyright ©2000 - 2022, vBulletin Solutions, Inc.
