01-17-2016, 06:29 PM | #1 |
Newbie Join Date: Jan 2016 Location: lakeville
| test
123
01-19-2016, 05:21 PM | #2 |
| Re: test
[ur
01-19-2016, 05:22 PM | #3 |
| Re: test
[ur
01-19-2016, 05:25 PM | #4 |
| Re: test
I upload 800x600 with postimage.org and I'm getting different numbers here
01-25-2016, 05:46 PM | #5 |
| Re: test
[ur
01-25-2016, 05:46 PM | #6 |
| Re: test
that says 800x450
02-02-2016, 08:28 AM | #7 |
MODERATOR Join Date: Oct 2010 Location: RC Land
| Re: test FYI: The forums image size limit is 800 pixels wide by 600 pixels tall... BUT..... If you force your image to be exactly 800x600 while editing the size to meet requirements, more then likely you will distort your image somehow (usually by stretching/distorting it top to bottom) Image editing programs and APPs will always pick the largest size and make the other match without distorting image. Most always it will keep the 800 and automatically lower the height number (600) 800 on width is the MAX because anything larger begins to push the vBulletin page of the forum past its usage limits. If a members image is extending past the toolbar width at the top of the page, the image is larger then the 800 pixel width limit rule. If you ever need help, (or anyone reading this), never hesitate to drop me a PM and I'll do my best to walk you through any questions. Image issues or any other issues. Looks like you've gotten your last image of the VW bug perfectly sized |
02-02-2016, 08:35 AM | #8 |
| Re: test
Example being... This top image is resized with the MAX width of 800 and the height auto-sized as to not distort image And this second image is manually the MAX of 800 on the width and forced to be the MAX of 600 on height Ultimately distorting image :-( |
02-06-2016, 07:43 AM | #9 |
| Re: test
[ur heres one with that says 800 by 450 looks huge on this page but when it posts its smaller Thanks for replying, I see in your example , but this pic seems like the numbers should be flipped. Hoping fully this pic isnt on its side Last edited by bittrclingr; 02-20-2016 at 05:16 PM. |
02-07-2016, 12:46 PM | #10 |
| Re: test
You're kinda right.... The image of the boy and truck is 450x800 The first number is always the width |
test - Similar Threads | ||||
Picture test test | picklewagon | Testing 1 2 3 | 0 | 02-27-2014 12:51 AM |
Noah's Twin Hammers speed test crawl test | noahzhou | Vaterra Twin Hammers | 13 | 02-15-2013 10:10 PM |
This is just a test, repeat.. this is just a test | Mr Blackwell | Testing 1 2 3 | 0 | 01-04-2011 08:57 AM |
test pic test(mike) | H3RESQ | Testing 1 2 3 | 1 | 10-20-2008 09:29 PM |
LOTS PICS, Shock test, Narrow Wheel Test, Tire Pattern Test, LOTS inside | Mutt | General Crawlers | 9 | 12-28-2005 09:30 PM |
