| | #1 |
| Newbie Join Date: Dec 2007 Location: in the middle of Germany
| Hi @ all, I want to produce my own alloy wheels with my own design. All what I need to do this are the measures. greetings Michael |
| Sponsored Links | |
| | #2 |
| Hi, is there no one there who have the rc4wd rockstar or narrow beadlock wheels for proline moab 40 xl tires? i need the dimension of the diameter behind the beadlock ring when the ring was demounted and also the depth of this diameter. the outer diameter of this wheels will be 107mm / 4.21 inch and the width 86mm / 3.38 inch. this dimensions i find on the rc4wd site. but the other dimensions i am allways searching for. please help. greetings Michael |
| | #3 |
| Rock Crawler ![]() Join Date: Sep 2005 Location: The Netherlands
| Sorry but i think this is rather stupid to ask, Nobody will give you the measurements because all those vendors and companies have did there research theirselves. And they wont give you their figures cause your even saying that you will produce them ! Sorry but just buy a set or measure you tyres and figure out yourself what will work. If you not skilled enough to make designs you own then your not skilled enough to make them i think. Succes though Beadlock Wheels You tried it once and i dont think people changed their minds , sorry Last edited by crawl rookie; 01-28-2008 at 01:31 PM. |
| Thread Tools | |
| Display Modes | |
