Go Back   RCCrawler.com Bulletin Board > RCCrawler General Tech > Tires and Wheels
Thread: New 2.2 wheels and tires from Integy
Old 01-27-2008, 02:19 PM   #1
Looking for scale goodies
Racer4Life's Avatar
Default New 2.2 wheels and tires from Integy
I am assuming these are beadlocks, but the information is still new.
Different colors available. 59.99 a set of two.
http://www.integy.com/cgi-bin/webc.c...d=5378&p_catid=
No photos yet.
Racer4Life is offline   Reply With Quote
Old 01-27-2008, 04:16 PM   #2
nope non beadlocks
http://www.tcscrawlers.com/Clearance...g-p-16379.html
i think those are the same wheels
nj05nismo is offline   Reply With Quote
Old 01-27-2008, 05:27 PM   #3
Racer4Life's Avatar
Originally Posted by nj05nismo View Post
nope non beadlocks
Those wheels have been out for a while.
Old 04-06-2008, 09:28 PM   #4
~The Scale Shop~
STANG KILLA SS's Avatar
$49.99 for two 2.2 beadlocks and two knock off moabs
good looking wheel. even has the center hub/nut cover.
http://www.shop.rpphobby.com/product...&productId=878
Old 04-06-2008, 10:35 PM   #5
Racer4Life's Avatar
Definitly a knock off Moab.
Wheel looks nice. Wish they sold them seperate.:-(
Old 04-06-2008, 10:56 PM   #6
Integy would probably sell more if they sold the wheels and tires separately
ussprinceton2004 is offline   Reply With Quote
Old 04-06-2008, 11:18 PM   #7
In between.
SACCO's Avatar
$100 for beadlocks, get a set of moab knockoffs for free sound better?
SACCO is offline   Reply With Quote
Old 04-06-2008, 11:24 PM   #8
They could have at least tried to make the tires look a little bit less than moabs. I am not gonna buy them cause they ripped proline right off.
Hellstomper is offline   Reply With Quote
Old 04-06-2008, 11:26 PM   #9
Wishing I was Crawling
ROSS's Avatar
that is a pretty cool looking wheel. integy is all about copying the moabs. they originally copied the moab XL.
ROSS is offline   Reply With Quote
Old 04-09-2008, 02:39 AM   #10
I joined the Band!
I dont care how cool any product looks. If its put out by Integy, I aint buying it.. Everything I have owned by Integy, has been pure garbage and there customer service is the worst Ive ever dealt with..
Knoc is offline   Reply With Quote
Old 04-09-2008, 05:54 AM   #11
Wow they've ripped off pro-line and rc4wd all in one go. Am I the only one think thoose bead locks look a lot to like rc4wds Rock Stars.
Tupers is offline   Reply With Quote
Old 04-09-2008, 05:26 PM   #12
Only the lock ring.
Here is a better shot of the Integy wheels... and they can use Axial lock rings too.
2JSC is offline   Reply With Quote
Old 04-09-2008, 09:34 PM   #13
That Was Totally Ninja!
rbgerrish's Avatar
If thoses 2.2 tires are anything like their super Moab XL ripoffs, they arent going to work at all. Integy copies everything...
rbgerrish is offline   Reply With Quote
Old 04-09-2008, 09:53 PM   #14
sorry if this sound racist, but its not meant to be. leave it up to the chinese to copy everything.
dragonracing is offline   Reply With Quote
Old 07-09-2008, 08:22 AM   #15
Hi,
Is someone has tested these wheels ?
I'd like to buy but I do not see the difference between these three models:
-Type I Wheel 2.2 Size & Crawler Tire
-Type II Wheel 2.2 Size & Crawler Tire
http://www.integy.com/cgi-bin/webc.c...d=5413&p_catid=
-Type III Wheel 2.2 Size & Crawler Tire
http://www.integy.com/cgi-bin/webc.c...d=5492&p_catid=
Even on the website Integy, there is no more.
Do you know what are the differences ? (Hex size ? Offset ? Size ?)
Thank you.
Sorry for my English, I'm french!
Bozolechat is offline   Reply With Quote
Old 07-09-2008, 10:17 AM   #16
WVB
Default All this ripped off stuff...
It's very feasible that Integy does not make either of these and in fact are produced by x company for them with their name stamped on...
This type of thing happens a lot especially in the sign world. I know of several companies stating their plotter is the best and cheapest, etc. But its really made by some one else. Some other companies state theirs is indeed made by Graphtec but boost their name to save money. Some of the features are removed or its not as fast as the name brand...
Has anyone tried these out..? Likes/dislikes..?
WVB is offline   Reply With Quote
Old 07-09-2008, 11:08 AM   #17
Racer4Life's Avatar
Originally Posted by Bozolechat View Post
Hi,
Thank you.
Between type 1 and type 3. The rings are the only difference. Type 2 shows to have the same rings as type 2.
Old 07-09-2008, 03:02 PM   #18
Thanks Racer4Life,
Ok for the ring between the type 1 and 3, but is it the only thing ??
And what about the type 1 and 2 ?
Nobody test this wheels and tires ?
Old 12-03-2008, 09:02 AM   #19
I have bought them. :-(
Ok, I should have read here before, I know.
Don't flame me now, please.
Wheels are nice. Beadlocks works well, the lockring has an OD of 64mm, which is 2mm larger than an Axial one (62mm), which is good at keeping seated and locked tires that have a slightly-larger-than-normal bead diameter.
In fact, the tires themselves are almost 2.3" and any other wheels I tried to switch them on failed.
Other than looking like a plain copy of a PL Moab with deeper thread, there's nothing good in these tires.
Compound is hard like good ol'Bruiser stock tires, eg. somewhat in between plastic and vinil.
I removed completely the useless foam inside, but even when empty the stiff carcass hardly flex enough to let the round thread to flatten and barely touch the ground. And that's under an 8 lb ax-10...
This is a tire that can only be used as allround backyard basher.
Maybe I'll try it on Bruiser wheels, it should at least look good under a Bruiser shelf queen
Cheers
rockspider is offline   Reply With Quote
