Go Back   RCCrawler.com Bulletin Board > RCCrawler General Tech > Tires and Wheels
Thread: Narrowed Junfacs
Old 02-02-2008, 11:09 PM   #1
Default Narrowed Junfacs
Well I got bored tonight and hacked up the Junfacs I have. I took a little less than 3/8 out of the center.I used my drill press and it worked very well. I also glued a 1/16 O ring the outer beadlock to get a better hold the bead. So far so good. I then decided that I was sick of the 3mm hardware and threaded it for 6/32 button head screws. No more stripping the mounting holes
Click the image to open in full size.Click the image to open in full size.Click the image to open in full size.
cyberhog05 is offline   Reply With Quote
Old 02-03-2008, 10:53 PM   #2
YTC Team Driver
winkscrawler's Avatar
Nice way to get an exact cut every time.
winkscrawler is offline   Reply With Quote
Old 02-04-2008, 10:39 AM   #3
Yep, thanks for the drill press idea!
holycaveman is offline   Reply With Quote
Old 02-04-2008, 12:01 PM   #4
SCALE PERFORMANCE PARTS
Locked Up's Avatar
What type of bit/cutting disc is that?
Locked Up is offline   Reply With Quote
Old 02-04-2008, 08:44 PM   #5
LIKES2CRAWL's Avatar
You can get Gator Discs at Lowes or Home Depot and it comes with the shank attachment.
LIKES2CRAWL is offline   Reply With Quote
Old 02-04-2008, 09:10 PM   #6
Awesome I got my junfacs in the mail today from TCS and there way to wide for my Rock Crushers.
Trimmy is offline   Reply With Quote
Old 02-05-2008, 01:10 PM   #7
It is from my air cut off tool
