| | #1 |
| Rock Crawler Join Date: Nov 2007 Location: Dayton, Ohio
| Ok I just got my Junfac Beadlocks today from TCS and was wondering what the easiest way is to narrow them and what kind of glue to use? I saw the post where the guy used a drill press to get a straigh cut but I dont have a drill press so how can I get a straight cut? Thanks Justin |
| Sponsored Links | |
| | #2 |
| RCC Addict Join Date: Nov 2007 Location: Scalers are more fun
| The last set of wheels I narrowed, I chucked a stub shaft in my hand drill and mounted the wheel up to it, and used a hacksaw to cut. Best glue? I used CA and it didn't hold up. I would think some kind of epoxy would work better? I've also seen people reinforce the seam with fiberglass. |
| | #3 |
| Pebble Pounder Join Date: May 2007 Location: Montucky
| you could always make a DIY drill press. Or im sure you have dremel so go get the drill press base for the dremel tool. It is sweet http://www.toolsforless.com/product/...ess_Attachment |
| | #4 |
| Dremel? Ya I got a dremel only problem is I dont know where it is. I have the carring case with all the bits I just cant find the dremel it's self!!! |
| | #5 |
| Quarry Creeper Join Date: May 2006 Location: Snake Run, IN
| I actually used the Truck and my lathe. Remove front driveshaft and put 1 wheel on the rear. Secure truck to workbench with said wheel hanging off edge. Have helper hold throttle and apply hobbie knife where needed. |
| Thread Tools | |
| Display Modes | |
