Go Back   RCCrawler.com Bulletin Board > RCCrawler General Tech > Tires and Wheels
Thread: 17mm
Old 02-06-2008, 08:23 PM   #1
Illeagle's Avatar
Default 17mm
Anyone tried 17mm hex's and if not, WHY not?
Illeagle is online now   Reply With Quote
Old 02-06-2008, 08:49 PM   #2
~The Scale Shop~
STANG KILLA SS's Avatar
my axial 40 series beadlocks use them.
Old 02-06-2008, 09:03 PM   #3
TEAM MODERATOR
Reflection's Avatar
My super and 14r run 17mm hexes. I feel it's a much better hex size and the buggy hexes are IMHO,a much better deal than regular wheelnuts.
Reflection is offline   Reply With Quote
Old 02-06-2008, 09:11 PM   #4
I'm using the 23mm
jimecm is offline   Reply With Quote
Old 02-06-2008, 11:49 PM   #5
MWRCA'er
Mnster's Avatar
I'm running the 17mm's on my super I really like them. Little more durable then the 14mm's.
Mnster is offline   Reply With Quote
Old 02-07-2008, 12:07 AM   #6
MWRCA'er
Mnster's Avatar
No there isn't. All of the 2.2's I've ever seen come in 12mm.
Old 02-07-2008, 05:45 PM   #7
TEAM MODERATOR
Reflection's Avatar
I think a 17mm hex for 2.2 is a little overkill. I like overkill though. I'd like to see some.
I've got Axial 40 series locks that are 17mm and Proline 40 series locks that are 17mm. My 14r is running Kyosho buggy wheels with a 17mm hex. I'd like to see an affordable lock in the buggy size with a 17mm hex. May have to just build a set. It's kinda nice if everything uses the same hex size. That way if you wanna try different tires or swap out between coarses,it's a quick swap.
