Go Back   RCCrawler.com Bulletin Board > RCCrawler General Tech > Tires and Wheels
Thread: wheels and foams
Old 02-07-2008, 04:09 PM   #1
Default wheels and foams
stupid question but i need to be sure. my stock axial wheels are running on air and ball bearings right now, my question is if i add foam inserts do i need to vent the rims or the actual tires themselves? in racing i vent the tires to allow dirt to be thrown out but i am not sure what works on crawler wheels. any help would be greatly appreciated.
jehuteh is offline   Reply With Quote
Old 02-07-2008, 04:56 PM   #2
NBRCC
hellbentrodder's Avatar
You will get much better traction if you vent the wheels. Two 1/8' per rim works well.
hellbentrodder is offline   Reply With Quote
Old 02-07-2008, 05:09 PM   #3
FYI just in case you want to go this way
memory foams
so you won't have a hard time looking all over the place
everyone is sold out right now except for TCS
i heard Xtreme Hobbies will have their by the end of this week
no word on the RCP Aces
chivas72 is offline   Reply With Quote
Old 02-08-2008, 11:53 AM   #4
WHITE LOTUS TERROR SQUAD
TURBOFEST's Avatar
yeah, get some memory foams and some stick on weights and loose the bb's...I run mine with no breather holes and they perform awesome...alot of guys do the 1/8 holes though. good luck
TURBOFEST is offline   Reply With Quote
Old 02-08-2008, 02:15 PM   #5
On the lookout for Rocks
constantmotion's Avatar
I'm running Ace Doughnuts and with Claws. My tires are vented and then perform a lot better than star cut or channeled foams
constantmotion is offline   Reply With Quote
Old 02-08-2008, 04:36 PM   #6
Gold Star Baby!
Stormin2u's Avatar
Location: Taylors Falls just hanging with the MNRCRC crew.
I have been using Kreepy red foams in the front tires and un cut stock foams (the ones that come with your tires) in the rears with a single 1/8" hole in each wheel. The hole helps the the tire to confom to the rock and creates a larger contact patch. I have found you want more traction on your fronts than rears when climbing if the rears bite to much they will take traction away from the fronts and thats bad because thats where the work really gets done.
Stormin2u is offline   Reply With Quote
Old 02-09-2008, 11:11 AM   #7
just got my new Losi Rockclawz-these are super soft and sticky!!
