| | #1 |
| Rock Crawler Join Date: Jul 2007 Location: Beechview/Pittsburgh
| Ok so I just spent a good part of the afternoon swapping my M2k, M3's from axial beadlocks to the new proline ones.. For the first time I actually pulled them out of the bead... and that was just rolling around the house.. To say the least unless you have a huge beefy bead on your tires dont bother trying to put the Mashers on them... |
| Sponsored Links | |
| | #2 | |
| I wanna be Dave Join Date: Jan 2004
I mounted some M3 Mashers on the Proline 8 shooters and had no problems. The wheels are very narrow compared to the mounting bead area of the Mashers so it is a little difficult to get things lined up.....but once they are all bolted up, I couldn't pull the bead out no matter how hard I pulled. | |
| | #3 |
| Quarry Creeper Join Date: Jul 2007 Location: south jersey
| i had a rock claw wrap around the knuckle and still not pullout out of the bead |
| | #4 | |
| Hmmm Maybe I need to retry mounting everything.. My translation is as follows... Took my current comp setup of Proline M2k's (M3 Compound) off of a set of axial beadlocks, and mounted them on Proline 8 shooter Beadlocks. To my surprise even after they were lined up I managed to pull the bead apart. THink I am going to try some new foams and remount them on the 8 shooters... that might be part of my issue... Quote:
| | #5 |
| Quarry Creeper Join Date: May 2006 Location: Next to your girlfriend
| Got a set of the new Proline beadlocks. I like the look of them being 10 bolts per side. Nice and narrow, cool rings. They go together like butter and hold realy well. I mounted a Losi claw and HPI Geolander. I have a set of IMEX G-Hawgs that have a think bead that could not be put in the grove of the axial rims. These rims will accept the thicker bead without any problem. The hex reciever fits as nice as the new axial rims. They should hold up well, well unless you are Dittohead [Grand master hex stripper] Problem #1- The first set I got my hands on. Rrght out of the bag they have 2 screws holding the rock ring on, and the factory had stripped them ALL. The 2 sets I got myself were ok :confused: Problem #2 - I mounted the 3 different tires and came up with the same thing. The rock rings OD is about 2mm to small leave the bead exposed. Thats my $.44 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() |
| | #6 |
| Rock Stacker Join Date: Feb 2008 Location: Rockwell
| I had the same bolt hole problem out of the bag. I can't even tighten some of the bolts up to fingertight. (up to 3 per wheel) I mounted a pair of Moab 2.2 tires and they wobble...I've gone around, remounted the tires and tried to get rid of the bounce. It's just not happening... The beadlocks themselves run true. Last edited by scaryfast12; 02-18-2008 at 08:50 AM. |
| | #7 |
| Newbie Join Date: Oct 2007 Location: Parkton
| A friend and myself both bought the prolines and put Masher 2k's on them and both had the bead come out repeatedly. I got home and mounted a moab on one and it seems to hold tighter than the mashers. A different bead maybe? |
| | #8 |
| I wanna be Dave Join Date: Apr 2005 Location: It's good to be a Pirate!
| I run a Masher Moab hybrid and I have no issues with either one. After reading this thread I went home and specifically pulled really hard on the tires. I cannot get them out. I don't know if you don't have the screws tight or not but even with the 2 strippers that I had as well it is solid as heck. |
| | #9 |
| Quarry Creeper Join Date: May 2007 Location: Seattle
| Running Masher 2k's also on the Proline wheel, no issue...they do not pull out of the bead for me either. Plastic wheels with metal screws will strip, so that's why you run a tap through them first and you're less likely to strip them out. |
| | #10 | |
| RCC Addict ![]() Join Date: Sep 2007 Location: Westland, MI
| | #11 |
| | #12 |
| Paypal....arghhhh!! ![]() Join Date: May 2006 Location: HONDURAS...ROCK HEAVEN
| | #13 |
| Rock Crawler Join Date: Dec 2007 Location: Tujunga
| If you are using the foams that came with the ax10 wheels they are too big and push the bead out annoyingly |
| | #14 | |
| Quarry Creeper Join Date: Aug 2007 Location: Im Your Neighbor
yeah same here i heard of a few people on here having problems mounting mashers to shooters. but myself i have had no problem and no blown beads. | |
| | #15 |
| RCC Addict ![]() Join Date: Jun 2007 Location: Waterford
| I just mounted my brand M3k M3 in my new proline 8 shooters and they were very easy to pull out of the beadlock:-( I guess the M2K go on another set of wheels and the new badland 2.2 will go on the 8 shooters |
| | #16 |
| RCC Addict Join Date: Oct 2007 Location: Commerce Twp.
| Just put 2 1/8 o-ring under the beedlock, problem solved. Works extremly well, on mashers it's almost a must. I will always use proline products Last edited by JUSTGOINGSLOW; 03-07-2008 at 10:31 PM. |
| | #17 |
| Bling Bling Bitches! ![]() Join Date: Feb 2008 Location: Winnipeg
| I just got a set of 8 shooters and bad lands and they clamp ok but I got screws too that I didn't even finger tight and they stripped? I wish I had known this b4 I bought them. I would have put that money towards some real beadlocks.... MSD's or Mayhem baby... Good thing it's not my comp rig but just prototype rig for tuning things... My comp rig is getting Mayehm's for sure now Not impressed... I will be emailing proline for sure! Now I know I'm not the only one with the issue! Last edited by PipeDreams; 03-10-2008 at 09:32 PM. Reason: Brain Fart |
| Thread Tools | |
| Display Modes | |
