Go Back   RCCrawler.com Bulletin Board > RCCrawler General Tech > Tires and Wheels
Thread: Ditching axials for narrow proline cheyenne
Old 02-17-2008, 10:55 PM   #1
Default Ditching axials for narrow proline cheyenne
I need to know what wheel adaptor i need for the new narrow proline wheels. I am running ttr cvd's and iI am not sure which ones will fit over them, I think they are 8mm o.d. shafts. Will they work on clod axles with just 23mm adaptor or should I get 23mm wideners/adaptors. I asked this in the clod section but not much responce there.
Team Jenny is offline   Reply With Quote
Old 02-17-2008, 10:59 PM   #2
666
666's Avatar
I use BENDER 12 to 23mm adapters, and something similar, gives me the just right width. Not sure where to get them anymore, so I'm alot of help.
666 is online now   Reply With Quote
Old 02-17-2008, 11:05 PM   #3
666
666's Avatar
These should work RCP 12 to 23mm adapters
The Thundertech plastic adapters may be a tad bit smaller than 12mm so if your "overpowered" or use them alot they will spin overtime. I used to JB Weld mine together to prevent that.
Old 02-17-2008, 11:46 PM   #4
Thanks 666. I think I can I think I can.
