Go Back   RCCrawler.com Bulletin Board > RCCrawler General Tech > Tires and Wheels
Thread: 40 Series Giant Tracs
Old 02-18-2008, 11:40 PM   #1
MBC Crew Chief
azvader's Avatar
Default 40 Series Giant Tracs
Click the image to open in full size.Click the image to open in full size.
I'm a hardcore Giant Trac fan. Finding them has become difficult as time goes on. Some of my back-up set have so much CA on the beads, I don't think I could re-mount them. I've also got a set still glued to the damaged rims.
My knuckle packs have almost no clearance with stock Clod wheels. The new 1500 mah 2/3A's I just built up have even less. I've been looking at new tire/rim options for awhile now. Beadlocks would be nice and some 40's would give lots of room for knuckle packs. What to do ????
Make some 40 Tracs. I started with some Axial 8-Hole oversized beadlocks, TTR 17mm CYD adapters, and an old set of Giant Tracs. First I marked around the tire about 1/4" above the stock bead and cut them from the rims. Next, the hard part, I loaded the tire into the bead channel. Finally I mounted the rings. This took some time but was well worth it !!!
I LOVE THEM !!!!!
azvader is offline   Reply With Quote
Old 02-18-2008, 11:54 PM   #2
Keep it real
Tanis's Avatar
Nice work
Tanis is offline   Reply With Quote
Old 02-18-2008, 11:57 PM   #3
Wishing I was Crawling
ROSS's Avatar
did you get a chance to test them, i have thought about doing this with my giant tracs but didnt know how they would do with such a small side wall, keep us posted.
ROSS is offline   Reply With Quote
Old 02-19-2008, 12:06 AM   #4
DIRTY SOUTH
Badd's Avatar
Heavy has been running Giant Tracs on 40s wheel for along time . this is the oldest pic I can find . But I know he has ran them longer than this . Although his are not on beadlock wheels . He has 1 win in SERCRC and many top 5s with them . Click the image to open in full size.
Badd is offline   Reply With Quote
Old 02-19-2008, 07:02 PM   #5
Click the image to open in full size.[/QUOTE]
I would love to see some more pics of the truck. I always enjoy your build threads.
J Rock is offline   Reply With Quote
Old 02-19-2008, 07:32 PM   #6
~The Scale Shop~
STANG KILLA SS's Avatar
no sidewall but they definatly look pimp! and all those horizontal tread blocks have GOT to grab something in a climb!
Old 02-19-2008, 08:31 PM   #7
There is a shop near me that has 4 of these tires,outrageous prices which is probably why they are still sitting there.
red jim is offline   Reply With Quote
Old 02-19-2008, 10:16 PM   #8
Whats the name of the shop.
What city, and phone#
IB..
I B RACIN is offline   Reply With Quote
Old 02-19-2008, 10:29 PM   #9
Keep it real
Tanis's Avatar
IB..
How many sets you need?........
Old 02-20-2008, 03:54 PM   #10
MBC Crew Chief
azvader's Avatar
Default I'm In
I need one more set of 4. GT's wear so long another set fixes me for life. Please PM me the info.
Thanks,
Mike
P.S. thanx for the compliment
Old 02-21-2008, 01:11 PM   #11
Nice work on those giant tracs. I love the set I have, I am going to have to dig them out and put them on my next build up.
Prime is offline   Reply With Quote
Old 02-21-2008, 05:52 PM   #12
Keep it real
Tanis's Avatar
Thanks,
Mike
I just reread my post and realized it came out wrong. Sorry, I don't have any, IBRACIN loves them, and buys any he can find, he probably has a closet full by now
But I agree, they don't wear out very fast, and work great on a variety of surfaces. Especially on Kevin's 2lb super:-P
Old 05-27-2008, 09:29 AM   #13
Hey Vader can we get an update on how these have been working for you?
rockwerks is offline   Reply With Quote
Old 05-28-2008, 09:59 AM   #14
holy crap batman!! those things look huge
BLAKE59RT is offline   Reply With Quote
Old 05-28-2008, 01:15 PM   #15
crawl rookie's Avatar
No they are not
smaller than for an example: 40 series moabs/mashers
crawl rookie is offline   Reply With Quote
Old 05-30-2008, 02:55 AM   #16
MBC Crew Chief
azvader's Avatar
Default Awesome !!!!
These work PERFECT !!!! As good as stock Giant Tracs but with beadlocks and more room for knuckle packs. Dad, James D, and I all run them and we discovered that old worn down GT's still work better than 40's Mashers or Moab XL's. After winning PARCs last comp with my Super, even Kevin's thinking about them.
Old 05-30-2008, 08:48 AM   #17
very cool! Ive got a brand new set here and a line on another set.
Ill be running them on my new super at Kaibab.......better watch out.!
Old 08-15-2008, 03:47 PM   #18
Not nay more you haven't .
Ho much of the original bead did you cut off azvader?? I just bought rockwerks set and I'm thinking of converting them for 40 series tyres.
Tupers is offline   Reply With Quote
Old 08-16-2008, 05:14 PM   #19
Three things you GT guys. First: If you've got an old set of GTs on a thrashed set of rims; or just have way too much CA glue on the bead you can pop 'em in the oven at about 150 farenheit for 10 or so minutes (I think - tip courtesy of CKRC Hobby) !!!MAKE SURE TO WATCH THEM, TIRES CAN MELT!!! When you pull them out (be careful they will be hot) the tires should pull right off the rim. While they're still hot the CA glue should come off as well.
Second: Just an idea, I'm not sure this can be done, but couldn't you guys just make a mold of the GT tire, melt down some other tire (something close to the same compound as the GT) and keep them or sell them. I know I'd buy a set if they worked.
Third, but CERTAINLY NOT last: Somebody could make a petition to bring back the Giant Trac tires and get people to agree to it and then send it into Pro-Line. (The two reasons I can't do this is because I have no clue where to start or where to go from there and because somebody who's sponsored by Pro-Line Racing could have more "leverage or impact".)
jeepcreep is offline   Reply With Quote
