Go Back   RCCrawler.com Bulletin Board > RCCrawler General Tech > Tires and Wheels
Thread: Tire siping?
Old 07-20-2004, 02:05 AM   #1
Default Tire siping?
Anyone siped their tires? When I start cutting mine, I am going to sipe them by running the cutoff wheel of a dremel down the treadblock, going in the dircetion of the tread. I think this may help out a lot. Just seeing if anyone has beat me to this. If so what do you think?
bustedcrawler is offline   Reply With Quote
Old 07-20-2004, 07:49 AM   #2
Default Re: Tire siping?
I glued side lugs on my narrowed kong's and the siping works perfect. It allows the tire to conform better if the siping is done in the correct direction. Sounds like your going length wise which still will increase grip. I used the dremel wheel also to create a gap for more flex unlike using a razor.
rcracer is offline   Reply With Quote
Old 07-20-2004, 09:49 AM   #3
i hate to ask this but whats tire siping?
firstumustcrawl is offline   Reply With Quote
Old 07-20-2004, 10:23 AM   #4
Cutting many "slits" into the tires lugs.
DirkDigler is offline   Reply With Quote
Old 07-20-2004, 10:31 AM   #5
After I narrowed my Kongs, I started siping them instead of removing tread. It leaves more rubber to contact the ground and it allows you to have more edges to grab.
Trac95ker is offline   Reply With Quote
Old 07-20-2004, 12:42 PM   #6
thanks dirk
