Go Back   RCCrawler.com Bulletin Board > RCCrawler General Tech > Tires and Wheels
Thread: imex boggers 2.2
Old 04-07-2008, 05:31 PM   #1
Default imex boggers 2.2
Hello new to this site and was lookin for some feedback on imex boggers. Do many use them on here or are they not a desired tire worth using,they seem a little short
m1smokey is offline   Reply With Quote
Old 04-07-2008, 06:04 PM   #2
Check out RC4WD's mudslinger tire. Its a little taller I believe and it is definatly more scale looking
Yotakid89 is offline   Reply With Quote
Old 04-07-2008, 06:06 PM   #3
PapaGriz Yo
Grizzly4x4's Avatar
and I think the RC4WD tire works better.
Grizzly4x4 is offline   Reply With Quote
Old 04-07-2008, 07:01 PM   #4
Yeah i heard it has a softer compound and provides more grip.
I have no real world experience with either though.
Old 04-07-2008, 07:13 PM   #5
Prick
rambuller84's Avatar
What are you gonna put them on?
rambuller84 is offline   Reply With Quote
Old 04-07-2008, 07:59 PM   #6
I've never ran Slingers, but 1.9 slingers look pretty scale...
As far as Swamp Dogs go... I ran a set back in the day... for just a trail/general tire they're not bad... They seem to wear out and get really crappy traction on rocks though... If you want a tire that does good "ALL AROUND" I'd go with Mashers... just my .02
grob23 is offline   Reply With Quote
Old 04-07-2008, 08:46 PM   #7
i run swamp dogs on my crawler and they work awesome, they get alot of grip and they are nice and soft, even in the winter when its 20 degrees outside
toomessedup is offline   Reply With Quote
Old 04-07-2008, 11:44 PM   #8
sorry didnt make myself to clear.Ihave the imex tire just lookin for feedback on them,havent seen much use of them.My truck is a homebuilt aluminum frame, wheely king axles,novack crawler,35 turn running on a cut down pede tranny (only gear used is the main diff gear with custom motor mount)that goes to a wk tranny then feeds th axles and all diffs are locked.dont get to see to many other rigs set up for crawlin around my area in person.Thanks for alls feedback.
Old 04-08-2008, 12:13 AM   #9
The swamp dogs are an ok tire they are a little to hard though. If you dont do alot of xtreme crawling they should work fine.
slowdown is offline   Reply With Quote
Old 04-08-2008, 12:31 AM   #10
dawgs are a bit dated now me thinks. I ran a set for a bit
Then I got a set of soft mudslingers,and they are much better. More grip, softer rubber, better looks, a bit taller than average. In my opinion, best 2.2 scaler tire available other than the crushers.
Ax-hole is offline   Reply With Quote
Old 04-08-2008, 12:35 AM   #11
MWRCA'er
Mnster's Avatar
Imex swamp dawgs are really not much better then stock WK tires...
I consider anything by Imex to be a stock replacement and not a hop up.
If your looking for a tire that performs well in loamy mud and wears like iron Imex works well for that.
If your looking for a tire that works well on rock climbs, seriously consider other tires.
Mnster is offline   Reply With Quote
