Go Back   RCCrawler.com Bulletin Board > RCCrawler General Tech > Tires and Wheels
Thread: 12mm Hexes???
Old 04-09-2008, 12:39 PM   #1
Default 12mm Hexes???
I am working on about 4 Axial Scorpion project and have ran into a problem. I have no 12mm hexes to put wheels on them, I know that i can cut the spacer off the original hexes and have on one set, but i may want to use them for original Axial wheeels later on. My questions are;
What hexes do I need to fit the Axial shafts?
Where is the best place to get them?
And if it helps to decide, I am Building 2 X-trails.
JBHardwear is offline   Reply With Quote
Old 04-09-2008, 12:51 PM   #2
Just a few threads back from this one is this thread with a link to some.
TunaMaxx is offline   Reply With Quote
Old 04-11-2008, 04:02 AM   #3
I shaved off the spacers on my Wheely King Hexes and now I wished I hadn't done it...I was wanting to use my Hi lift wheels so I was impatient.
Now I have axial beadlocks so I have to find some alloy hexes with that same spacer.
Sasquatchbagger is offline   Reply With Quote
Old 04-11-2008, 08:01 AM   #4
if you buy some plastic wheel sets (RPM, Pro-Line, Traxxas, etc.), they usually come with various 12mm hex adapters
ussprinceton2004 is offline   Reply With Quote
