Go Back   RCCrawler.com Bulletin Board > RCCrawler General Tech > Tires and Wheels
Thread: Losi Foams or Axial Foams in Claws
Old 04-12-2008, 07:05 AM   #1
2D
Harvo's Avatar
Default Losi Foams or Axial Foams in Claws
I mounted some claws up last week using the foam that came with them in a typical star cut. I think they might be too soft now. They look ok on the roll but fold over almost too easily under side loading.
I have read several posts about people using the stock Axial Lizard foam in the claws and they seem to like it. Would someone please go into more detail about why people are liking the Axial foam in the Claws?
I have some Axial foams on the workbench, but the thought of unscrewing - rescrewing all those beadlock bolts is making my imaginary carpal tunnel flare up. :? Don't want to do it if it's not worth it.
Thanks!
Harvo is offline   Reply With Quote
Old 04-12-2008, 09:36 AM   #2
While I get that this would require opening up the beadlocks (which sucks), a picture might be helpful. It is possible to take out too much foam, and it sounds like you might have. Not sure about other folks, but I don't have strong feelings about the Losi foam vs the Axial foam.
Mortimer Snerd is offline   Reply With Quote
Old 04-13-2008, 10:15 AM   #3
Gold Star Baby!
Stormin2u's Avatar
Location: Taylors Falls just hanging with the MNRCRC crew.
The most common Claw set up is memory foams in the fronts and unmolested stock foam in the rear. This set up provides the right front to rear traction. Memory foam all around gives the rear tires to much bite and takes away from your front traction by lifting the front wheels slightly.
Stormin2u is offline   Reply With Quote
Old 04-13-2008, 04:10 PM   #4
im running stock axial foams in mine and they work well, the stock ones i thought were too stiff and i start cut them and didnt really like how that worked...
severed701 is offline   Reply With Quote
Old 04-13-2008, 07:28 PM   #5
2D
Harvo's Avatar
That is what I'm getting with the stock Losi foams star cut. They get into a crevase or undercut ledge and just wrap around the rock with so much bite it will do a back flip... on near flat ground!
I have the stock axial foams that seem really stiff. I may do some light cutting on a couple of those for the rear.
Thanks
Old 04-14-2008, 04:52 PM   #6
Buy a set of memory foams and solve all your concerns I bought some Kreepy's and Memory Makers and don't regret it at all. Makes a world of a difference and well worth $25.00 (Memory Maker or Aces are 25).
procraft98 is offline   Reply With Quote
Old 04-14-2008, 07:43 PM   #7
honestly...i dont think i would ever fun memory foams. Ive considered it several times. But with the temp variation and the fact i like to run year round they just dont make sence. At our last comp it was 50*f out, and the guys who were running MF's were running on square tires because the foam couldnt react fast enough. I just got a set of the "all weather stretch" foams from TCS and am loving them, every bit as good as my dads memory foams (and WAY better in the cold), stretched the tire a little bit (see pic below), and nice soft center with plenty of sidewall stiffness...Best part is they are 7 bux for a pair and are unaffected by the cold
stock foam on the right...tcs stretch on the left...
nj05nismo is offline   Reply With Quote
Old 04-14-2008, 07:54 PM   #8
Stock axial's are definately softer than stock losi's.
MattG is offline   Reply With Quote
Old 04-15-2008, 11:20 PM   #9
i run stock losi foams in the rear and i am actually using 1.5 ace donuts in each front. i found with just 1 mem foam donut was to soft so i cut one in half and put that in with a full one. stiffened her up a bit and made sidehilling better, doesnt collapse so fast now
Scottish is offline   Reply With Quote
Old 04-15-2008, 11:27 PM   #10
I run kreepy reds all around with good luck.
Josh87 is offline   Reply With Quote
Old 04-16-2008, 08:48 PM   #11
2D
Harvo's Avatar
Well... I kept the stock Losi star cut foams in the front (they are perfect), and in the rear, I put in the Axial Foams with a modified star cut. It has more points with 3/16" flat tops. I also sliced a groove down the center radially.
When I first mounted them up I wasn't sure I liked them because the axials are much wider, rounding out the sidewalls. (versus the flat sidewalls with the Losi foams) they flattened out some and look much better now. Most of all they perform excellently. They still have great traction, but now they don't foldup when they get it.
