| | #1 |
| Newbie Join Date: Apr 2008 Location: Elizabeth
| I just got my 1.9 Rock Stompers in the mail, along with my white wagon wheels 1.9 from rc4wd. Should I use wheel weights, or bbs? I am building more of a trail rig, but I want to crawl a little bit as well. If I use bbs, how many oz. should I use? If I get wheel weights, where do I get them? Walmart? And how much weight should I use? I will be building a High Lift, with the 1.9 Rock stompers. I might 4 link it, but for now, I will keep it pretty much stock. Leafs, 3 speed tranny, etc. I am ordering the soft springs from rc4wd as well though. THX |
| Sponsored Links | |
| | #2 |
| I am a Liar! Join Date: Aug 2007 Location: santa monica
| if its a trail rig you might not like the noise the bb's make...you also wont need much weight in them. You'd only notice needing weight when you started to crawl some technical stuff. |
| | #3 |
| ... Join Date: Sep 2005 Location: USA
| I've got my 1.9 Rock Crushers filled 90% with 12g AirSoft BB's. I'll get the weight later and post up. |
| | #4 |
| MWRCA'er ![]() Join Date: Apr 2004 Location: Byron, IL
| I just do a few creek crossings and my foams absorb the fishy water, thus weighting my tires. |
| | #5 |
| I wanna be Dave Join Date: Jun 2004 Location: Not where I'd like to live
| I use 2oz. on the front & 1 oz. in the rear. I'm thinking about adding some to the front though. |
| | #6 |
| also, I use 3-3/4 oz each front, 2-1/4 oz each rear in addition to the weight of the beadlocks on both my gwagon and range rover 'trail' rigs... you've seen the videos of what I crawl. The weight makes a nice difference on the rocks, not so much on real easy trails. check my videos... http://youtube.com/user/pantablo |
| | #7 |
| Newbie Join Date: Jul 2006 Location: NOR*CAL.....Bay Area
| I am running 5oz per front wheel and 2.5oz per rear. I used the stick on wheel weights, I got them for free from pep boys by asking the service department. |
| | #8 |
| Pebble Pounder Join Date: May 2008 Location: alberta
| omg what is that and where can i get one |
| | #9 |
| Rock Stacker Join Date: Apr 2008 Location: Mississauga, ONT
| Whats the weight on thos...per wheel? |
| | #10 |
| RCC Addict Join Date: Apr 2006 Location: On Da' Shelf
| That looks kewl Zip, but what does that have to do with this thread? |
| | #11 |
| what kind of foams you run with that!? |
| | #12 |
| Id like to see some video of it crawling, 27oz per wheel seem like a lot. I mean im rumming about 18oz in my fronts ea. because i have my batterys mounted in the rear to make up the weight diffrence but thats cutting it close with the amount of weight on the foams.....starts to get kinda squishy. |
| | #13 | |
| Rock Stacker Join Date: Jan 2008 Location: my house
| | #14 |
| Rock Stacker Join Date: May 2008 Location: MIDDLE OF THE DESERT
| Sorry can't post any more about this for now.:-( |
| | #15 |
| Well the new and improved, WHEEL PIG, THE MOST VERSTAILE WHEEL WEIGHT SYSTEM FOR RC ROCK CRAWLERS, is alive and kicking and will be avaialble right here on RCCRAWLER.com in the vendor's section. Don't be fooled by imitations! There is only one WHEEL PIG! Just to remind you all of what it is, below is a picture of the original Wheel Pig. New ones are a bit different. WHEEL PIG... A BUNCH OF UGLY DYN-O-MITE! |
| Thread Tools | |
| Display Modes | |
