| | #1 |
| Rock Crawler Join Date: Sep 2007 Location: Denmark
| A new scale tire ? Or crawler tire ? What do you think? ![]() Designed for all-terrain action, each corner of the Slash is equipped with soft-compound tires that are mounted and pre-glued on impressive 2.2" satin-finish wheels. The tires deliver the perfect balance of forward traction and side bite on asphalt, dirt, and any other surface you throw at them. Performance tuned foam inserts help keep the truck firmly planted through the most extreme power-sliding turns and on the most demanding off-road terrain. |
| Sponsored Links | |
| | #2 |
| I wanna be Dave Join Date: Jan 2004
| Quote: |
| | #3 | |
They also work on dirt, and any other surface | |
| | #4 |
| I wanna be Dave Join Date: Jan 2006 Location: Henderson/Las Vegas, NV
| scaler maybe, crawler no. |
| | #5 |
| Rock Stacker Join Date: Apr 2008 Location: Mississauga, ONT
| Not a bad looking tire is i may say so! |
| | #6 |
| It looks a little like the HPI Geo´s .... Or the Proline Flatiron |
| | #7 |
| Rock Crawler Join Date: Mar 2008 Location: hillbilly illinois
| look like a good scale tire. Maybe not the best crawler. Hows the compound? |
| | #8 |
| Rock Crawler Join Date: Aug 2005 Location: Idaho Falls
| I would say it will not be a good crawler tire, not even close, but I think it would look good on a scale rig. |
| | #9 |
| Pebble Pounder Join Date: Feb 2007 Location: St.Marys County, MD
| I can see alot of these ordered for some scalers, heck they would look good on my tuber. |
| | #10 |
| I am a Liar! Join Date: Aug 2007 Location: santa monica
| those might work on my jeep truck build...cut down to a 3.7" tall 1.9er.... |
| | #11 | |
| | #12 |
| Quarry Creeper Join Date: Jan 2008 Location: SW of Cleveland
| Do they use 12mm hexes? Will they be sold umounted? Last edited by Phatmac; 04-17-2008 at 03:18 PM. Reason: I meant 12mm, and hate to look like a stupid newbie. |
| | #13 |
| It's a setup! ![]() ![]() ![]() Join Date: Jan 2004 Location: The Crawler State
| | #14 | |
http://www.buytraxxas.com/default.php?cPath=1_1630_1651 Tires & Wheels Accessory Parts Listed in Blue Part Part Name+ Price Buy Now 5116 Ball bearings, blue rubber sealed (5x11x4mm) (2) $3.50 Buy 1 'Ball bearings, blue rubber sealed (5x11x4mm) (2)' now 5114 Ball bearings, blue rubber sealed (5x8x2.5mm) (2) $4.00 Buy 1 'Ball bearings, blue rubber sealed (5x8x2.5mm) (2)' now 1747X Blue-anodized, aluminum flanged lock nuts (4mm) $5.00 Out of Stock Notify Me 3647 Nuts, 4mm flanged nylon locking (steel, serrated) ( 1675 Oilite bushings (5x11x4mm) (14) $5.00 Buy 1 'Oilite bushings (5x11x4mm) (14)' now 1647 Silicone grease $2.00 Buy 1 'Silicone grease' now 2754 Stub axle pins (4) $1.00 Buy 1 'Stub axle pins (4)' now 1985 Teflon washers, 5x8x0.5mm (20) (use with ball bearings) $2.00 Buy 1 'Teflon washers, 5x8x0.5mm (20) (use with ball bearings)' now 5875 Tires & wheels, assembled (5-spoke, beadlock style 2.2'' satin chrome wheels, off-road racing tires, foam inserts) (front) (2) $30.00 Out of Stock Notify Me 5873 Tires & wheels, assembled (5-spoke, beadlock style 2.2'' satin chrome wheels, off-road racing tires, foam inserts) (rear) (2) $30.00 Out of Stock Notify Me 5871 Tires, off-road racing, 4.3x1.7- 2.2'' (2)/ foam inserts (2) $20.00 Out of Stock Notify Me 1654 Wheel hubs, hex (2)/ stub axle pins (2) $2.00 Buy 1 'Wheel hubs, hex (2)/ stub axle pins (2)' now 3654 Wheel hubs, hex (tall offset, Rustler/Stampede front) (2)/ axle pins (2.5x12mm) (2) $3.00 Buy 1 'Wheel hubs, hex (tall offset, Rustler/Stampede front) (2)/ axle pins (2.5x12mm) (2)' now 5874 Wheels, satin chrome, 2.2'' (5-spoke, beadlock style) (front) $8.00 Out of Stock Notify Me 5872 Wheels, satin chrome, 2.2'' (5-spoke, beadlock style) (rear) $8.00 Out of Stock Notify Me 3685 White plastic washers (5x8x1.0mm) (6) $2.50 Out of Stock Notify Me Displaying 1 to 16 (of 16 products) Result Pages: 1 Shopping Cart more 0 items * Shipping Not Included Featured Products more Shaft, lightweight output / idler gear shafts (2) (hard-anodized/ Teflon-coated aluminum) Shaft, lightweight output / idler gear shafts (2) (hard-anodized/ Teflon-coated aluminum) $12.00 Find a Local Hobby Dealer Click below to find a Hobby Shop near you! Hobby Retailer Last edited by SnoopMaxx; 04-17-2008 at 03:36 PM. | |
| | #15 |
| Traxxas Tires Off-Road Racing Slash http://www3.towerhobbies.com/cgi-bin...?&I=LXUWA5&P=7 Traxxas Wheels Satin Chrome Rear Slash http://www3.towerhobbies.com/cgi-bin...?&I=LXUWA7&P=7 Traxxas Slash http://www3.towerhobbies.com/cgi-bin...lash&search=Go |
| | #16 |
| ~The Scale Shop~ ![]() Join Date: Apr 2006 Location: KILLEEN TX
| if they were M2 compound and had a thin carcuss, i think the tread lends its self to a great crawler tire. but yes i will be a welcome tire in the scale arena. will look good on my trophy truck build for sure. |
| Thread Tools | |
| Display Modes | |
