Go Back   RCCrawler.com Bulletin Board > RCCrawler General Tech > Tires and Wheels
Thread: New beadlocks from Junfac
Old 04-14-2008, 04:21 PM   #1
Default New beadlocks from Junfac
New beadlocks from Junfac! Cheap too!
http://www.junfac.com/shop/index.php...=index&cPath=5
bretkissick is offline   Reply With Quote
Old 04-14-2008, 04:30 PM   #2
On the lookout for Rocks
constantmotion's Avatar
They look pretty good
Always liked Junfacs.
constantmotion is offline   Reply With Quote
Old 04-14-2008, 05:54 PM   #3
PapaGriz Yo
Grizzly4x4's Avatar
Good to see they are a little narrower than the Mudrocks. The width was the only thing I didn't care for on my Mudrocks.
Grizzly4x4 is offline   Reply With Quote
Old 04-14-2008, 05:58 PM   #4
Cheap and A Good Look to them
JBHardwear is offline   Reply With Quote
Old 04-14-2008, 06:57 PM   #5
Liking these things!!
http://www.junfac.com/shop/index.php...products_id=16
Oze30 is offline   Reply With Quote
Old 04-14-2008, 08:13 PM   #6
...dood was JUST about to post these..they look REALLY good...Just in time for me to buy new rims too Go the RED route or Murderish Black? Still no Axial Green which IMO is a good thing :-P
EDIT: DOODS!!! Check this out!! You get ALL these parts!!!! Mix and match for your only colour variations!!! (stealing pics as i speak)
Gmade GT 2.2" beadlock wheels x 2
Nylon beadlock rings x 4
Silver aluminum beadlock rings x 2
Silver aluminum center plate x 2
Stainless steel silver round head bolts x 32
Stainless steel silver cab head bolts x 12
BitHed is offline   Reply With Quote
Old 04-14-2008, 08:14 PM   #7
These are my favorite, only $13.90 :-P
Old 04-14-2008, 11:05 PM   #8
C U S T O M P A I N T
CrawlerGraphics's Avatar
Great looking wheels and cheap...
CrawlerGraphics is offline   Reply With Quote
Old 04-14-2008, 11:30 PM   #9
Are these plastic with aluminum rings? Either way the prices are awesome.
Thundermaxx is offline   Reply With Quote
Old 04-14-2008, 11:37 PM   #10
Junfac are all plastic however they do offer the optional extra of purchasing aluminium rings! Placed my order ;)
genki is offline   Reply With Quote
Old 04-15-2008, 12:14 AM   #11
...Junfac ARE plastic but the new COLOURED wheels come with that outside ring in alloy...The backside hoop is plastic though...And that funky little hub cover is alloy...Just ordered a silver set...
Old 04-22-2008, 11:34 PM   #12
Default Update
Yay!! My set arrived...EXACTLY one week (to the hour actually) from order and payment to arrival...Pretty stoked...I have made up ONE and went with black screws instead of the supplied blingy silver ones...
...Quality is good, colour is good, fit and finish is good, so much screwing is bad...in this sense...
...FYI the STOCK AX10 hex hubs wont fit the hole unless you drillit out to 7(?) or 8(?) mm, whichever it was...i checked it last night...Also that little center cap wont fit on if your axle protudes too much, which mine does with RPM 12mm hex hubs...I will be drilling out the center to fit the AX! hubs tonight...Pics when i have it looking right
Old 04-23-2008, 05:49 AM   #13
I am charmed with these
mactech is online now   Reply With Quote
Old 04-23-2008, 06:40 AM   #14
the other option is the grind down that little "hub" portion or use hex's that dont have them. That way you dont have to drill your pretty new wheels
nj05nismo is offline   Reply With Quote
Old 04-23-2008, 07:16 AM   #15
...good idea...that makes sense
...grind or drill grind or drill...
Old 04-23-2008, 07:24 AM   #16
grind that way you can change wheels in the future and not have to drill...plus hexs are cheap. did you get the solid center cap?
Old 04-23-2008, 08:37 AM   #17
...Nismo I owe you one
...found some old but unused plastic HPI hexes with the nipple...2 out of 4 now have no nipples..I had to put the baby to sleep between #2 and #3...
...This means that my center cap will NOW fit over the protuding axle AND the few extra mm in clearance now means that the rims dont hit the lower links or the shox Stylin'!!
I dont actually like the center cap though
Old 04-23-2008, 08:57 AM   #18
no prob...i take it you have the solid center not the one with the hole in it. The solid center cap does nothing for me. Not particularly scale and makes it a PITA to take the wheels off. The one with the hole in it looks ok, would look better with a MSD scale nut
Old 04-23-2008, 09:09 AM   #19
...oh ok i see what you mean now
..Let me explain...
...The silver cap is jst that, a silver cap that bolts on...
...What appears to be the BLACK cap with the HOLE in it is ACTUALLY the WHEEL...The screws you see bolt directly INTO the wheel...
...The picture that bretkissick posted of JUST the black rim is the SAME rim as you get, just without the center cap and the outside silver ring...
...I know what you mean about the nut...I had a black one on but it looks MUCH better with a silver one...
Old 04-23-2008, 09:48 AM   #20
ahhh...in the pics it looked shiny as if it was a seperate metal peice.
