Go Back   RCCrawler.com Bulletin Board > RCCrawler General Tech > Tires and Wheels
Thread: Grooving/Cutting tires?
Old 04-16-2008, 08:23 AM   #1
Default Grooving/Cutting tires?
To everyone out there that has cut or grooved their tires with a Dremel. What sort of blade should I use. Im going to try grooving my Crushers. Any pics of what have done could also help. Thanks
kizzo is offline   Reply With Quote
Old 04-16-2008, 09:26 AM   #2
On the lookout for Rocks
constantmotion's Avatar
Reinforced Cut-Off wheel........don't have to be the reinforced, but that's all that I use anyway.
constantmotion is offline   Reply With Quote
Old 04-16-2008, 10:59 AM   #3
Makin "Bank" in ND!!
racerx's Avatar
If you want wider grooves you can stack the cut-off disks also.
racerx is offline   Reply With Quote
Old 04-16-2008, 11:49 AM   #4
Does anyone have pictures of some grooved or cut tires ? just need some examples. I was thinking about grooving my mashers to try to compete with a set of claws.
toytech93 is offline   Reply With Quote
Old 04-16-2008, 06:08 PM   #5
Wear protective gear, gloves, glasses and mask (filter for your breathing).
I tried cut-off discs, high speed cutter and diamond wheels. In the end I used stacked diamond wheels (should have stacked more), if I had had larger diameter high speed cutter would probable have used that but the collet kept rubbing the tire shoulder. When I was done there was rubber dust everywhere and some smoke...
I was sneezing some black stuff for days. But now I have Mud Thrasers that look like Mashers.
Yours
Spot(T)
Spot(T) is offline   Reply With Quote
Old 04-17-2008, 08:07 AM   #6
Perpetual Newbie
Cave Dave's Avatar
Cave Dave is offline   Reply With Quote
