| | #1 |
| Newbie Join Date: Oct 2007 Location: Branson
| So i have a set of jordan tires on my crawler and really like them, But i just cant get over the rc4wd swampers they just look to stickin cool to pass up but, they are just 5 inches tall. .... the jordan tires are hugh for 2.2 and they work great on my super ..... i have 4 moab tires and would like to make a set jordan swampers i guess you could say. how would i go about making them taller like right at 6 inches ? thanks for any help -mirra Last edited by Mirramaxx; 04-17-2008 at 11:10 AM. |
| Sponsored Links | |
| | #2 |
| Gavyn is my BFFL ![]() Join Date: Feb 2007 Location: hunting pandas
| | #3 |
| Rock Crawler Join Date: Jun 2004 Location: back in Portland, OR
| you'll need like 5 or 6 swampers (i asume ou are talking about the mud slingers, yes?) cut them perpendicular to the tread and add tire sections so that the tire becomes the height you want it. if you have the capabilites to run a 14mm or 17mm hex you can make them big enough to fit on a standard maxx size wheel (3.2") which should make your tire to be about 6". If you can only put these on a 12mm hex wheel you could make the tires big enough to fit onto a jato 2.8" wheel which would give you an outer diameter of 5.6". If you want to put these on a 2.2 wheel you will have to glue some 2.2 sidewalls in to bring the inner diameter back down to 2.2". hope this helps here is a link to a custom tire with a similar concept: LOSI ROCK CLAWS Supersized do some searching if this still doesn't help. |
| | #4 |
| yeah the mudslingers are what i was talking about, thanks for the links I'm gunna do a little research and see what i can come up with. thanks again ! -mirra |
| Thread Tools | |
| Display Modes | |
