| | #1 |
| Quarry Creeper Join Date: Jan 2008 Location: SW of Cleveland
| I clean my tires with Simple Green, and I have even read (here, I'm sure) that it's beneficial to "paint" it on and let it dray to keep the tire stickier and cleaner. I was also thinking about spray-on tire chains. Like this: http://www.sportsimportsltd.com/lisptichgr.html I remember a local news channel spraying a car's tires with pine resin of some sort, and then driving a car on an ice rink with good results. I bash in areas with a lot of dirt and leaves as much as rocks, so I would think it could be counterproductive in that environment (picture tires wadded with twigs and leaves and small stones). But what about on wet rock or "clean" rock? Has anyone tried this? Do you have any other tricks that you're willing to share? |
| Sponsored Links | |
| | #2 |
| RCC Addict Join Date: Mar 2005 Location: Saginaw
| Do a search for "softening" in the Tires and Wheels section. There are a few different techniques and compounds that people have tried, with varying results (including Simple Green, which you mentioned). |
| | #3 |
| Quarry Creeper Join Date: Feb 2008 Location: Weddington
| Simple Green |
| | #4 |
| Rock Crawler Join Date: May 2007 Location: lacey
| paragon ground effects is very popular at my local track for the off road clay racers, it actually seems to keep the dust from the track off the tires, plus with repeated use, the tires get really soft. never bought any, but if I had some you know it would be on my crawler! |
| | #5 |
| Pebble Pounder Join Date: Dec 2006 Location: nampa
| any sort of Tracktion compound that your local track guys are useing will help perfomance, Paragon Jack the Gripper, umm there are many others out there but the 2 that comes to mind at the moment |
| | #6 |
| Keep it real ![]() Join Date: Jun 2006 Location: Yakima,WA
| I don't do anything anymore, just run them Last edited by Tanis; 04-17-2008 at 11:37 PM. |
| | #7 |
| Quarry Creeper Join Date: Jun 2004 Location: aurora, CO
| any one try belt dressing? for power steering belts? that gets really sticky and it even says on the can "improves traction" apply it before every run the can only costs 4 bucks |
| | #8 |
| But the problem with adding sticky stuff is that dirt and debris builds up on your tires, and unless you clean it off before every application, you're going to have a big mess. |
| | #9 |
| MWRCA'er ![]() Join Date: Apr 2004 Location: Byron, IL
| I like WD40 still, it maintains the softness. On my super truck I'd definitly say the tires are more sticky and soft. |
| | #10 |
| Rock Stacker Join Date: Nov 2007 Location: Commerce Twp.
| | #11 |
| RCC Addict ![]() Join Date: Aug 2007 Location: Rohnert Park
| Try Buggy Grip 2 from Trinity, it's used in off-road racing and should work great. |
| | #12 |
| OCCUPY RCC! ![]() Join Date: Dec 2005 Location: I am the 53%.
| Try some Crawler Tape from JP CUSTOM RC's. |
| | #13 |
| Quarry Creeper ![]() Join Date: Nov 2007 Location: san diego
| i agree with tanis |
| | #14 |
| Pebble Pounder Join Date: Mar 2007 Location: Delaware, OH
| Sorry to necro post, but I actually used the search function before posting, and found this thread. Aren't you oldies proud? I'm kind of surprised this topic hasn't been well received by the crawling community. I thought for certain that any kind of traction compound would be illegal for crawling, but didn't find anything in the USRCCA rules about it. I remember seeing a lot of oval racers using "tire sauce" on their foam tires, and in my mind, it made sense that using a similar product for crawling would be a closely guarded secret if it weren't illegal. But it appears that no one really uses anything. Simple Green was the first product that came to my mind. I used it on my Revo tires when I raced, and it certainly helps. |
| | #15 |
| AWESOME! TOTALLY AWESOME! ![]() Join Date: Oct 2007 Location: gervais
| how do you use the simple green? sorry for jacking the thread but I was just wandering. |
| | #16 | |
| Web Wheeling ![]() Join Date: Jan 2005 Location: Twin Cities
| | #17 |
| Just apply to tires liberally and dab off any excess, let the rest just soak in. It kind of conditions the tires and keeps them soft. It doesn't really have a traction element, but it does seem to leave behind a little residue that is somewhat sticky. |
| | #18 |
| well I got a bottle of concentrated simple green and it's in a spray bottle, do I mix it with water or leave it concentrated? |
| | #19 |
| | #20 |
| Gold Star Baby! ![]() Join Date: May 2007 Location: Taylors Falls just hanging with the MNRCRC crew.
| I like to mix some simple green in a dish pan with about a 1/2" of water when I scrub my tires. I does a great job of making them look like new. |
| Thread Tools | |
| Display Modes | |
