Go Back   RCCrawler.com Bulletin Board > RCCrawler General Tech > Tires and Wheels
Thread: Hot racing Clod wheel adapters/spacers
Old 04-20-2008, 09:13 AM   #1
Default Hot racing Clod wheel adapters/spacers
I picked these up from Liquid RC for about the same price as the Integy ones I had that I wasn't pleased with. What I liked about them was that they fill the huge hole in the wheel that the Integy ones don't. They also bolt on to the axle just like a wheel and then the wheel bolts to them, that way they never fall off when doing repairs or anything. They also have this little O ring that acts as a lock washer inside the wheel nut which by the way is 17mm instead of the crappy 7mm ones that are commonly used with other addapters. It still uses the stock flange nuts to hold down the addapter to the axle but I still think it's a better setup. Just thought I would give up some kudo's for some good work and ingenuity and see what others thought as well.
jeepfreek is offline   Reply With Quote
Old 04-20-2008, 09:51 AM   #2
those look much better then the integy adapters
saul is offline   Reply With Quote
