| | #1 |
| AWESOME! TOTALLY AWESOME! ![]() Join Date: Oct 2007 Location: gervais
| I know most people say get metal beadlocks but I don't much money so theres three beadlocks I'm thinking of the axial beadlocks the pro-line 8 shooters and these http://www.junfac.com/shop/index.php...roducts_id=197 which is better? like as in narrow and durability? |
| Sponsored Links | |
| | #2 |
| Rock Crawler Join Date: Nov 2007 Location: Dayton, Ohio
| I had a set of Junfacs and axial, I personally like the axials better. I have no experience with the 8 shooters so I have no comment on them. |
| | #3 |
| well which one is narrower? and how do the the screws hold up in the axial and the junfac? |
| | #4 |
| Quarry Creeper Join Date: Feb 2008 Location: ICE BERG HELL
| I use all axial wheels, they are nice and narrow and have NEVER had a problem with the screws. But the trick isnt the wheels, its installing them, take a bit of finess and ONLY do it by hand. Doesnt matter who's wheels you buy, the holes are going to strip out if you get rough with them. I know alot of the reason for the metal wheels is weight, but i just use stick on weights you can get at the auto part store, you cant get alike 12 oz worth of weight for a couple bucks. Reason I havent tried JunFac wheels, I cant find with width measurement for them and I prefer that the tires be wider than the wheels when installed. Just my thing. |
| | #5 |
| Quarry Creeper Join Date: Jan 2008 Location: marysville
| Peeps run metal for either the look, the weight, or don't want to strip a wheel hex |
| | #6 |
| Rock Crawler Join Date: Apr 2007 Location: Denverish
| I haven't seen the Junfacs, but I've played with the Axials and Prolines, and like the Axials better. The Prolines seem to strip more easily, and I think they're too narrow. |
| | #7 | |
| Quarry Creeper Join Date: Sep 2005 Location: on the rocks
BTW I run 2 screws tight by hand on my locks and use a screwgun for the rest | |
| | #8 |
| SCALE PERFORMANCE PARTS ![]() Join Date: Oct 2007 Location: College Station, TX
| I have all Axial wheels and glued the hexes in before any stripping started. I've gone through a few sets of slipper gears for my WK and have yet to strip a wheel hex. I'm not shy with the skinny pedal either... |
| | #9 |
| Dream...Think...Create. ![]() Join Date: Jun 2007 Location: Crawler Innovations, Tyler, TEXAS
| How long your bead locks last and what brand of bead locks can somewhat depend on the amount of voltage, motor and gearing you run. I've stripped more bead lock hexes and plastic hexes with higher voltage and low gearing. I never had the problem with a 6 cell sub C. The newer axials have done well, and gluing in the hex helps, but I have stripped the hex itself, not the hex on the wheel. If you crawl a lot, the wear and tear over time is what gets you more then the occasional time you get bound up. Aluminum bead locks are by far the best. The Erikison's are great too and cheaper. Check out the vendor section. |
| | #10 |
| Throwing Grenades ![]() Join Date: Jul 2004 Location: Sending illegals home one Hayabusa at a time.
| For a little bit more you can get the Delrin machined Eritex beadlock wheels. They have the benefits of machined wheels but for an awesome price. Just find Eritex in the vendors forum. I have three sets of his wheels now, I also own a few sets of the Visionary Fab billet wheels but they are a lot more. One thing, my Delrin solids weigh more then my VF billet wheels, and the Eritex comp heavies weigh even more. |
| | #11 |
| Newbie Join Date: Mar 2008 Location: Bloomington
| I use the Pro-line 8 shooters and have not had a problem with them and no striped holes since pro-line has repackaged them |
| | #12 |
| Rock Crawler Join Date: Jan 2005 Location: Windsor, VA
| I have a set of axials and the hexes didn't last very long at all. It seems that the plastic around the hex gives and lets the hex spin in the rim. Using the same hexes with some narrowed RPM wheels with no problems. Even got metal hexes, and still have the same problem with the axial beadlocks. |
| Thread Tools | |
| Display Modes | |
