| | #1 |
| Newbie Join Date: Dec 2005 Location: northern UTAH
| Im trying to install a set of hammers with full uncut foam on a set of 8shooter rims and the tire keeps pulling out of the bead. should I cut the foam if so, how much. Pics would be really helpful. thanks. |
| Sponsored Links | |
| | #2 |
| Pebble Pounder Join Date: Mar 2008 Location: The state of 'Missery'
| I had a hell of a time mounting my hammers also,I did like Dirk suggested in another post and used a drop of CA to tack the bead to the wheel and you should be good to go. |
| | #3 |
| Newbie Join Date: Jan 2008 Location: Scottdale
| I just mounted up a set of M2 Hammers to my 8 Shooters this week and didn't have any trouble...just took my time. |
| | #4 |
| Yea I really only had a problem with one tire out of the set,might have had my foam bunched up or something. |
| | #5 |
| Newbie Join Date: Dec 2007 Location: Peabody
| It helps if you pull the bead of the tire on the other side out past the wheel bead so it holds the beasd you are working on . I then use a rattle can cap to push the tire and wheel down on (the side you just finished) so I can hold the tire in the final bead.... Did that make any sense what so ever? |
| | #6 |
| RCC Addict Join Date: Mar 2006 Location: Xxx
| Because my patience is next to nill , I pull my beads while sitting on the crapper. Its utterly amazing the concentration and time you take to apply all for rubbers into the beads all while dropping the kids off at the pool. I did my M2 flat irons and M3 hammers all in one shitting. |
| | #7 | |
| Pebble Pounder Join Date: Aug 2007 Location: Broken Arrow, OK
| | #8 |
| Pebble Pounder Join Date: Dec 2005 Location: orono,me
| yea hammers are a pain to mount to any beadlock i have found out. i used a drop of ca to help get mine mounted to my ericsons |
| | #9 |
| Web Wheeling ![]() Join Date: Jan 2005 Location: Twin Cities
| My hammers dropped right into my Eritex beadlocks, but the badlands I have do not like the rc4wd rims I put them on. Maybe some runs are better then others on these tires? |
| | #10 | |
| Gold Star Baby! ![]() Join Date: May 2007 Location: Taylors Falls just hanging with the MNRCRC crew.
| | #11 |
| Rock Stacker Join Date: Apr 2008 Location: Mississauga, ONT
| Heres a little tip that i use eveytime and iv never had a problem mounting any tires on any beadlocks. Try wraping rubber bands around the tire in a star pattern between each of the screws on the beadlock |
| Thread Tools | |
| Display Modes | |
