05-04-2008, 04:35 PM | #1 |
Rock Stacker Join Date: Apr 2008 Location: houston
| Added weight and now worse than before!
so last night I got around to finally adding weight ti my wheels and I was expecting great results because now when I lift a single tire the articulation is great. Way better than before. now when I crawl at the same place at before it feels lick the rig has less traction than before. gets hung up more and does not like to climb.My rig is an ax10 rtr and these are my mods so far. no foamssub c batteries located around steering servolocked front, duh55 turn intigy10 tooth pinion6oz weight in each front9oz weight in each rearthat is all I believe. the reason I added more to the rear is because I am running the larger battery pack on the front compared to others running the 2/3A cells but this may have been a mistake, maybe.
05-04-2008, 04:45 PM | #2 |
Quarry Creeper Join Date: May 2007 Location: NCVRCC
| wheel weight
Most guys run more weight in the front wheels. You want you front heavier than the rear. On an uphill climp your weight will transfer to the back. Keep adjusting until it is right for your driving style. |
05-04-2008, 05:19 PM | #3 |
RCC Addict Join Date: Apr 2005 Location: Eden Prairie, MN
| If you added weight, and it acts worse than before, take off the weight... It's pretty simple to me. What were you trying to accomplish with the extra weight? Just to ballance the front and rear more? If you felt it was too front heavy, you could always get a different battery pack for the front that is smaller and in turn lighter than your current one. (like a 2/3a pack) |
05-04-2008, 05:26 PM | #4 |
Don't worry about balancing the weight. The battery is on the front axle for a reason...to keep the weight of the batteries as far forward as possible. You want more weight forward than you would rearward. You're running no foams? Are you running bb's or are you just running them with air trapped like a 1:1 tire? Maybe it gets hung up more because the added weight makes the tire sidewalls bulge more meaning the axle is a bit lower than before? |
05-04-2008, 06:05 PM | #5 |
RCC Addict Join Date: Mar 2006 Location: Bedias, Texas
Weights with no foams? That would be the problem is my guess also. I've never been a fan of running pneumatic tires on a crawler. The bounce alone is enough to drive someone crazy, lol. My suggestion would be to get yourself a good set of foams (memory foams if possible), vent the wheels (small hole only), and then try adjusting your weights until you get the right combo for you, your rig, and the terrain you crawl. David Xtreme Rc Hobbies |
05-04-2008, 06:10 PM | #6 |
yeah, I was still trying to keep some weight on thr rear so it could still push the front tire up the vertical wall in front of it but I willprobably take all but maybe an ounce or two out of the rear. and see is that helps. also are the stock axial lizards that bad. every one seems to be dogging on them but I am pretty happy with mine.
05-04-2008, 06:15 PM | #7 |
RCC Addict Join Date: Jul 2006 Location: Pasadena
upgrade to some proline M2 compound tires of your choice, run foams and lower the rear weight and you will see why everyone dogs the lizards so much. lizards dont like grab that much.
05-04-2008, 06:19 PM | #8 |
I wanna be Dave Join Date: Nov 2006 Location: spring hill TN
The stock tires do suck compared to others on the market. I am with everyone else on the fact that you need to get yourself a good set of foams and if you are still running the stock tires you need a set of new tires to. As far as adding weight to the rear so it will push the front up steep climbs there is no need to. When you start to climb up a wall the weight is pushed to the rear of the truck. I personally run some weight in the rear but not alot unless it is on a droop truck or a torsion rig.I would say try to stay around 2-3oz in the rear and in the 9-14oz range in the front. |
05-04-2008, 07:39 PM | #9 | |
thanks, that sounds good. I was looking at the losi crawlers. I realy like the way the truck feels and crawls with out foams though. I realy dont have a problem with bounce. I am going to try to go to the local crawler comp here and maybe some one will let me test drive there truck and I can see the differance with out having to buy memory foams and then think they suck or something. trying to stay on a budget as I am looking forward to the release of the traxxas slash at the end of the month. | |
05-04-2008, 08:32 PM | #10 | |
Rock Stacker Join Date: Dec 2006 Location: in front of a computer
05-04-2008, 09:09 PM | #11 |
Nope.. Join Date: Aug 2005 Location: Whiteland, Indiana
I don't think the foams are as much of a hangup as the excessive weight in the rear. You're basically pulling yourself down the hill instead of pushing yourself up.
05-04-2008, 10:10 PM | #12 | |
thank you, that is what I am going to do is remove all of the weight from the rear. thanks for staying on topic. Last edited by jc052685; 05-04-2008 at 11:14 PM. | |
05-04-2008, 10:32 PM | #13 |
Newbie Join Date: Apr 2007 Location: in my house
You asked, why you have less traction now? Most are saying no faoms is the issue because we/they have tried the other ways and found out what works and what doesn't. So they are on point, don't ask for help and then tell them that they're wrong. -----YOU ASKED THEM.----- They answer and you complain. Imagine if you will, put alot of pressure on a ballon it will wobble back and forth and be hard to control. Now do the same to a pillow [put pressure on it] and it compress's. Now apply it to tires. -----------------------------------------------------------Be careful what you ask for you just might get it!
05-04-2008, 11:07 PM | #14 |
That made no sense what so ever. He never said they were wrong. He actually did the opposite sand said he DIDN'T know everything and that's why he was asking. So, calm down Skippy.
05-04-2008, 11:32 PM | #15 |
well your name preceeds you, I was making a point about tires with air and tires with foam. Tires with air float and do not contour to the service there going over, unlike a compressed foam. I Hope my point gets across. Using terms like skippy are not condesending at all. So maybe now you understand. |
05-04-2008, 11:36 PM | #16 | |
once again, thank you for paying attention. | |
05-04-2008, 11:42 PM | #17 |
trial and error for the most part. Why is it so hard to believe that foams are right and will help your truck perform better. And I will agree with the others about the weight being to much. I run even weight so as climb I get plenty of traction and when I go down a hill it doesn't lightnen up to much and flip forward. And it's weight were it is most needed on the wheel.
05-04-2008, 11:59 PM | #18 | |
05-05-2008, 01:42 AM | #19 |
Quarry Creeper Join Date: May 2007 Location: melbourne, australia
it all depends on how you like the car too drive foams are not always the best option down here in Victoria, Australia the top 3 place getters at our comps run no foam, i have won 2 out of 3 of the comps this year and i run no foam and breather holes in the rim this works for me because i run a very light car, i have only added about 80grams (not sure what that is in ounces) of weight in total in my front wheels with a lipo battery on the front axle, the only weight on the chassis is the tranny and a 550 can motor (i could go to brushless to save some more weight but i like the speed, torque, and feel of the brushed motor, that i cant get from a brushless) the tires only just fold under on sidehills, but nothing that causes me to roll where others don't the traction you get is insane compared to the foam setup this method has been tryed and trued down here because the guys i crawl with have been doing this since before this site existed, and they haven't found a better setup so really try different things and see what works, go to a few comps and see what the top place getters are running talk to people it's the best way to learn, i know from experience |
05-05-2008, 02:46 AM | #20 |
now,that is some good advice. Thank you for your input.
