Go Back   RCCrawler.com Bulletin Board > RCCrawler General Tech > Tires and Wheels
Thread: clod tires
Old 07-29-2004, 05:08 PM   #1
Default clod tires
how many people run cut and shut clod tires
bigred is offline   Reply With Quote
Old 07-29-2004, 09:42 PM   #2
Default Re: clod tires
I'd say 95% of people with a clod run clod tires. We don't have many options and generally they do ok. I run cut tires on narrowed rims w/ extra backspacing..
Shut?
SR5Dave is offline   Reply With Quote
Old 07-29-2004, 09:48 PM   #3
sr5dave cut and shut means you cut them then you close them the shut means close them
Old 07-30-2004, 12:37 AM   #4
I'm just having trouble picturing how you shut a tire, do you mean narrowing the tires? Or glueing them to the rims?
Old 07-30-2004, 12:53 AM   #5
31st place in 2006 Nats!!
toyofast's Avatar
Cut tire down middle, cut away a section of tire, discard that cut section and then reattach the two halves to make a narrower tire.
See, stock Kong tire(4.5" wide) next to a cut'n'shut Kong tire(3" wide)....
They work great too!
toyofast is offline   Reply With Quote
Old 07-30-2004, 09:53 AM   #6
OK, I've just never referred to it as 'cut n shut'
I thought about it for the clod tires, buuuut... If you took like an 1.5" out of em it'd be cool, but you'd have trouble getting a rim to the right width, I'd imagine.
Old 07-30-2004, 11:34 AM   #7
well not to pirate the post but do you run foams in the narrowed kongs? and alos can a stock maxx rim fit the kongs cause that would make them bulge over slightly or am i wrong?
firstumustcrawl is offline   Reply With Quote
Old 07-30-2004, 11:13 PM   #8
Okay i was wondering why does everyone make there tires narower. Don't Wider tires give you better traction.
ChevyPedeCrwlr is offline   Reply With Quote
Old 07-31-2004, 12:26 AM   #9
techincally no more pounds per square inch a 2 inch tire with a 16 pound truck that means 4 pounds per tire now a truck with 4 inch tire thats only 2 pounds definetly dont quote me on the numbers im not sure how that works but i know why it does what it does but this all goes away in sand or super loose dirt cause you wantt he weight distributed cause then it wont sink in hope that helped
Old 07-31-2004, 01:17 AM   #10
toyofast's Avatar
Oh, please for the love of god... proof read when trying to type something technical!! I have no flippin' clue as to what you said.
Old 07-31-2004, 01:22 AM   #11
toyofast's Avatar
Currently no foams. I do need to add a bit of foams for more sidewall strength, they want to fold over at times and a bit of foam would help ease that.
I have no idea how big a stock Maxx wheel is. These are just the wheels that came in the Kong tire combo.... I narrowed the wheels down to about 1.5" wide though. There is some bulge from the tires but not much, about .75" per side. It's quite easy to narrow the rims if needed. I still need to soften up the Kongs and groove them for added flex. The tread blocks are kinda stiff in stock form.
Old 07-31-2004, 10:59 AM   #12
FUMC.. You do have the right idea, aside from it all being one sentence ;)
narrow tire=more pounds per sq inch. Too wide and you just float, too narrow and you just sink in. On rock you'd think that narrow is always good, but its not the case cause you fall in holes.
I think most will agree.. clod tires are a bit too wide I think having a 3" wide clod tire would be cool, but they're not that special of tires anyway, so why put the time into them?
Old 03-06-2005, 07:41 PM   #13
correct me if im wrong but wouldnt a larger contact patch = more traction.... if not then race cars would run narrow tires .... also wouldnt wider tires help in preventing roll overs by widening the track of the truck?
triaxmaster is offline   Reply With Quote
Old 03-08-2005, 01:42 AM   #14
You'd think that would make sense, but in crawling and in off road it doesn't.
rckjeep is offline   Reply With Quote
Old 03-08-2005, 04:17 AM   #15
I have only ever ''cut and shut'' narrowed any of my tyres for the pure purpose of gaining more steering and manauvrability .
Wider tyres do have a larger contact patch and also have more chance of gaining a foothold on any little steps or crevises but are wide ,clumsy,the steering suffers from wide tyres and have more of a chance to get you stuck in pinches or wedges.
Russell is offline   Reply With Quote
Old 03-08-2005, 10:58 AM   #16
Wider doesn't always mean better. If you were mudrunning (for example) you would want a taller skinny tire over a large balloon tire so that your tire would more or less sink to the bottom to get traction on (solid) ground. The wider tires might cover more area, but they aren't grabbing anything but slippery mud. Fine if you try to "float" over the mud with speed, but not good for creeping through.
In crawling both variations might prove to have the advantage. It depends on many factors including terrain, tires, driving ability, plus many more.
But, everyone has there own opinions.
Jam1sstang is offline   Reply With Quote
Old 03-08-2005, 07:45 PM   #17
Hey guys, sorry about all the grammar screw-up's I was in a rush that night. But thank you for answering my question's and not totally ripping me a new one cause of the errors.=)
Old 03-08-2005, 09:55 PM   #18
it seems that clod's always run cut tires. are there any tires that you don't have to mod that will work good??
baldy806 is offline   Reply With Quote
Old 03-08-2005, 10:00 PM   #19
moabs work great stock just narrow the rim about an inch.
kwj48 is offline   Reply With Quote
