05-22-2008, 04:17 PM | #1 |
Newbie Join Date: Mar 2008 Location: transfer
| tire foam
what dose the different tire foam shaping do to the tire and how it grips and how to determine how much weight gose in what tire is there a role of thumb for it
05-22-2008, 04:37 PM | #2 |
Newbie Join Date: Feb 2008 Location: Connecticut
The foam shapes are used to simulate lowered tire pressure which in turn allows the tire to conform to the rocks. When using regular foams most will star cut the foam to get this effect. How much weight will vary from rig to rig. I have 6 oz and 3 oz front and rear respectively. You'll want more weight up front. Hope this helps.
05-22-2008, 05:05 PM | #3 |
what or should i say how dose the stars get cut in to the foam any size or dose it have to be just the right way dose any one have any pics
05-26-2008, 12:33 PM | #4 |
Newbie Join Date: Apr 2008 Location: Dayton (Beavercreek)
Try this site, about halfway down the page. http://clodzone.com/?p=386 Good luck1 |
05-27-2008, 03:23 PM | #5 |
I wanna be Dave Join Date: Mar 2007 Location: roland,ar
you want to simulate low tire pressure? cut the foams in half vertical,make them as wide as the rim,now your simulating low psi. never understood the star cut thing. |
06-12-2008, 11:15 PM | #6 |
Newbie Join Date: Oct 2006 Location: Northern CA
It's meant to simulate airing down for off-roading, not a half-flat tire.
