Go Back   RCCrawler.com Bulletin Board > RCCrawler General Tech > Tires and Wheels
Thread: Anybody use TerraCrusher tires?
Old 08-20-2004, 04:11 AM   #1
Default Anybody use TerraCrusher tires?
Hi guys! I just mounted a set of the TC tires on my TXT. I don't know if they will work well or just plain suck, but I figured that they were atleast worth a shot since they are a full 7 inches tall. On beadlocks, they are 3.5 inches wide. Cutting a pattern into the tread lets the carcass flez well, but the blocks are still hard.
August 28th will be the next crawl out here by me; I'll be crawling with KonaJoe and Trac95ker. I will get to give the TCs a good testing session then. Untill then, anybody else ever try them? Vince
fullmodtxt is offline   Reply With Quote
Old 08-20-2004, 10:48 AM   #2
Default Re: Anybody use TerraCrusher tires?
next to Jumbomaxx tires..
SR5Dave is offline   Reply With Quote
