11-25-2008, 03:41 PM | #1 |
Newbie Join Date: Apr 2008 Location: the hell thats NJ
| cutting tire foam??
Just got proline hammer tires with memory foam. i was going to glue them down and be done with it. read somewhere that cutting them into a pointed star help performance. can or should i do this with memory foam?? going to wrap he center of the wheels with stick on weights or is there something better i should use? thanks for the help mike |
11-25-2008, 03:45 PM | #2 |
11-25-2008, 06:36 PM | #3 |
I joined the Band! Join Date: Jul 2008 Location: ohio
i second that .dont do it .will make them way to soft
11-25-2008, 07:54 PM | #4 |
ok what about the stick on weights or bbs? just want to get it right the first time thanks
11-25-2008, 08:31 PM | #5 | |
Pebble Pounder Join Date: Jul 2007 Location: Shorewood
sorry for the mess on my post 1 to meny Last edited by thevulgarcowboy; 11-26-2008 at 04:11 PM. | |
11-26-2008, 04:11 PM | #6 |
RCC Addict Join Date: May 2005 Location: Auburn, WA
| I run my truck every day with BB's in the tires. If you're breaking wheels you're breaking wheels, that isn't the fault of the weight you use. And if you're that worried, pick them up if you do break a wheel.
11-26-2008, 08:18 PM | #7 |
i just goto my local tire shop and get 1/2 oz stick on weights i run 9.5 oz in each front and 2 oz in the rear they seem to work well but everyone has there own setup |
11-26-2008, 08:21 PM | #8 |
RCC Addict Join Date: Sep 2007 Location: Westland, MI
Do not cut the foams the come with the Hammers. They work great. And stick on weights. |
11-28-2008, 08:45 AM | #9 |
Pebble Pounder Join Date: Aug 2008 Location: Indonesia - Rock Heaven
yup..cutting foams into star shape just making the foams softer and softer after each run....then they're unusable...
11-28-2008, 01:36 PM | #10 |
Rock Crawler Join Date: Aug 2007 Location: mesa az
dont cut the foams and do yourself a favor buy some beadlocks that way if you dont get it right the first time you can always change it later
11-28-2008, 02:19 PM | #11 |
Quarry Creeper Join Date: Mar 2008 Location: Huntington Beach
Ya it will make foams to soft and tires will wad up on u. Also sidehilling will suffer since there is no sidewall support in the tire. Also you get to much rear bite in the tire on verticle climbs flipping backwards much easier too.
11-29-2008, 07:01 AM | #12 |
thanks anyone know a pretty cheap beadlock wheel?
12-04-2008, 01:31 AM | #13 |
Quarry Creeper Join Date: Nov 2005 Location: Italy
Proline 8 shooters or Axials or Junfac Gmade are first to come to mind, cheap, and all them feature plastic centersection with alu rings. Proline 8 shooters are the narrowest of the group, if that matters. |
