02-11-2009, 11:53 PM | #1 |
I wanna be Dave Join Date: Oct 2006 Location: Centered
| Rim and Tire Venting Methods?
Like 1/4elliptic toys, I'm also in the market for a new set of 2.2's and after looking through his "Show off your 2.2 beadlocks" post and seeing that most of the replies are aluminum beadies, I thought it might be cool to have a thread with pics and tech info on prefered methods and tools for venting aluminum and Delrin rims, as well as tires. So how do you go about it, and why that way? |
02-12-2009, 05:47 AM | #2 |
I always just vent the wheels. Drill one 1/8" hole in each wheel. Works great for me.
02-12-2009, 06:32 AM | #3 |
I wanna be Dave Join Date: Jan 2004 Location: Detroit
I always do the tires. Mount the tire then cut holes for escape. Depending on foam/tire 2-4 per tire works real well. With holes in the tires the are can escape without having to travel through the foams (not an easy task for some dense memory foams. Also holes in the tires allow water back out much better should you run in the water. And no they do not become more prone to ripping. Last edited by binaryterror; 02-12-2009 at 07:45 AM. |
02-12-2009, 06:49 AM | #4 |
Rock Crawler Join Date: Aug 2008 Location: Alamogordo
How do people vent the CDPs from Mayhem?
02-12-2009, 09:33 AM | #5 |
I wanna be Dave Join Date: Feb 2007 Location: BFE, NV
02-12-2009, 05:15 PM | #6 |
Pebble Pounder Join Date: Dec 2008 Location: Victoria, BC
Just out of curiosity, has anyone tried valving the vents in order to allow fast compression and slow the rebound? I'm kind of envisioning two holes, one of which is totally open and the other of which has a butterfly-style valve which allows air to pass out of the tire freely, but restricts/stops the flow of air in? Or am I nuts? |
02-12-2009, 05:58 PM | #7 |
Rock Crawler Join Date: May 2008 Location: Mansfield, PA
I only vent my tires.... I put two or three (3/32" -to-1/8") holes in the center of the tire tread. A leather punch or a red-hot coat hanger works best. Venting the tires is "better" than venting the wheels because centrifugal force keeps dirt and water OUT of the tire. Venting tires has been common practice in off-road RC racing (buggy,truggy,MT) for years, but seems like it is just catching on in the crawling world. and like binaryterror said...venting the tires will not cause them to rip or tear. I have vented hundreds of tires and never had any of them rip. btw, Venting your wheels is fine... but it is not nessesary, and not to mention I don't to drill vent holes in my $200+ dollar RC wheels |
02-12-2009, 07:28 PM | #8 | |
Newbie Join Date: Feb 2009 Location: Las Cruces
1/8 hole in the rim for me. | |
02-12-2009, 08:51 PM | #9 |
Pebble Pounder Join Date: Sep 2008 Location: n.e.pa
even thou i am new to this crawlig world - i vent both tire and rim -3 holes in the tire and 2 in the rim - just my 2 cents
02-12-2009, 09:28 PM | #10 |
RCC Addict Join Date: Nov 2005 Location: Saving for Nationals!!
I just leave one screw out of the inner locking ring. All of my Aluminum Beadlocks are already drilled through in that manner, and one less screw won't cause you to lose a bead in with 8 or more holding the rings normally... |
02-13-2009, 03:14 PM | #11 |
RCC Addict Join Date: Jan 2008 Location: www.rccrawler.com
Binary and other guys who vent tires please post a photo ...where do you make the holes sidewall or what?
02-13-2009, 03:22 PM | #12 |
02-13-2009, 03:29 PM | #13 |
I've been doing 3 or 4 holes for about a year. Air moves in and out easier, and faster. Make the foam do all the work. You can see the Rover and stock foam air gap... |
02-13-2009, 04:08 PM | #14 |
I wanna be Dave Join Date: Jul 2008 Location: appleton
1/8 drill bit into the inner side of the rim
02-13-2009, 04:14 PM | #15 |
Newbie Join Date: Dec 2008 Location: Rio Grande Valley, TX
x2 on drilling inner side of rim.
02-13-2009, 07:29 PM | #16 | |
Tire venting seems like a good way to go...I was concerned about the the integrity being compromised by doing that, but it sounds like they hold up well. Has anyone experimented with hole location? I see you and Eee Pee go dead center...how about sidewall or a combination of locations? | |
02-14-2009, 03:13 AM | #17 |
RCC Addict Join Date: Feb 2008 Location: tauranga north island new zealand
if you holed the sidewall ,it would more likely rip id say.
02-14-2009, 06:26 AM | #18 |
02-14-2009, 06:50 AM | #19 | |
Sidewall would get caught by rocks more so and lead to ripping. I know people and Berg steering knuckles have caught a tire and ripped them. | |
02-14-2009, 09:42 AM | #20 |
I don't think location really matters all that much as far as being more effective over another location. With multiple holes you're always going to get the venting action. I used the HB logo on the sidewall for consistency. All and all, I don't think it really matters whether you vent a rim, or tire, just make sure you have enough holes in whichever, and the air isn't restricted to move in and out as fast as it can. |
