03-29-2009, 03:25 PM | #1 |
RCC Addict Join Date: Jan 2009 Location: Sebastopol CA
| What size drill bit for drilling wheels to use with Axial Hex's?
I got some shiny new Eritex Delrin Comp Heavy's in the mail a couple days ago for the Berg I'm building. This is my first set of wheels so please correct me if I'm wrong, but I belive I need to drill out the center hole's to use them with Axial aluminum hex's. My question is, what size drill bit should I use? Thanks! |
03-29-2009, 07:49 PM | #2 |
So I just got home from work, and I'm holding my drill bits up to the axial Hex's. It looks like I need to drill each wheel's center hole out to 1/4"? Is that correct? It doesn't look like it would leave much wheel for the wheel nut to hold onto? |
03-29-2009, 07:59 PM | #3 |
RCC Addict Join Date: Aug 2006 Location: ****, SL,UT
or you can just cut the little stubs off?
03-29-2009, 07:59 PM | #4 |
I wanna be Dave Join Date: Dec 2007 Location: Not here
You may want to check with Eritex on this but on my wheels I machine that hole to 9/32 .281 dia. |
03-29-2009, 08:08 PM | #5 | |
| I guess I could. Or I could try to find some flat hex's. Just seems like I've read that a lot of wheels need to be drilled out. Quote:
Looks like my 1/4" drill bit would be 1/32 too small..... | |
03-29-2009, 08:26 PM | #6 |
Pebble Pounder Join Date: Jan 2009 Location: Crestview
i don't remember the size, but i used a Uni-Bit to drill out 3 sets of MSD's. i think it is the 3rd. step. just drill slow, you will get it.
03-29-2009, 08:44 PM | #7 |
I just talked to Gerame (Eritex) he suggested grinding down the hex's rather than drilling the wheels. He said it would be stronger that way. So, I'm gonna give that a shot. Now to find a grinder I can borrow. Thanks for all the tips guys. |
03-29-2009, 09:01 PM | #8 |
Rock Stacker Join Date: Mar 2009 Location: Angeles City, Philippines
you can just use a sand paper instead of grinder... it's plastic right? a rough metal sand paper and a few strokes should do the trick.
03-29-2009, 09:03 PM | #9 |
RCC Addict Join Date: Aug 2005 Location: VARCOR
The real Axial hex spacers are aluminum..............but yes, I would grind/sand/cut those down before altering some of Gerame's craftmanship.
03-29-2009, 09:15 PM | #10 | |
These: http://www.ckrccrawlers.com/shop/ind...roducts_id=920 That smallest bit that sicks out needs to come off. | |
03-29-2009, 09:16 PM | #11 |
03-30-2009, 05:05 PM | #12 |
Well, I ground down the nipple on my hex's just now. I don't have a dremmel yet, so I used my harbor frieght angle grinder. They're not pretty, but I think they'll work. Here's a tip for anyone who's doing the same: Take the little set screws out of the hex's and put them aside before you start. They vibrate loose and vanish . Luckily I had a spare. I think I'm also gonna shop around for some flat faced clamp on style hex's for future use. |
03-30-2009, 06:57 PM | #13 | |
03-30-2009, 07:36 PM | #14 | |
I hate having the drive pins fall out whenever I take off a wheel, that's why I swapped out the stock Berg hex's. | |
03-31-2009, 05:39 PM | #15 |
03-31-2009, 06:00 PM | #16 |
I'm gonna look around for something like these. http://www.inetrc.com/store/index.cf...=59&Category=7 |
