05-23-2009, 04:05 PM | #21 |
Quarry Creeper Join Date: Feb 2009 Location: Richmond, VA
05-23-2009, 04:10 PM | #22 | |
The reason i am asking these question is because it seems tires/ foam/ weights and rims are very important in this hobby. maybe even more important than the engine in a crawler. so i want to know how to get the optimum performance out of my tires. last quetion? are those vp rims really worth the money? i am not a comp competitor, but i would like to get some good rims. thx everyone for putting up with my quetions and replying to this thread | |
05-23-2009, 04:40 PM | #23 |
| it wears them a tad but just enough i only do it for up to 30-40 seconds it scuffs them up to get good grip and letting the tire flex on the rocks brakes them in. but the softer= more grip
05-23-2009, 05:20 PM | #24 |
I wanna be Dave Join Date: Jul 2006 Location: The beautiful Pacific Northwest
Wow guys, all I do is drive my truck to break in the tires, no chemicals for me. Seems that the more I drive, the better my truck performs. When the tires seem to be losing performance, I replace them.
05-23-2009, 05:38 PM | #25 | |
| Personally,I just mount them up and run them. Having allot of wheel speed helps "break in" a tire faster. A few blips of the throttle and they are "scuffed" Kinda like wheel weights IMO....it's personal preference. I've seen guys that run near bald Mashers and claim they are just starting to hook the best. I've seen guys take tires with 3-4 comps on them and claim they are wore out and pitch them. Personally,I try to run them till they are nearly bald. Quote:
Foams are very important. A bad foam set up can kill even the best tire. IMHO,foams are a personal preference as well. Some like memory foams. I think they are overrated myself. Some like a tall,skinny and stiff foam,some like a short wide soft foam. Right now,I'm running Cougars with the stock 400 foams and like it very well. Before I went to the 400 foam,I was running 2 stock Axial foams in each tire and it seems to work very well also. Kind of a pain to get them both in there,but they worked good. The VP wheels are VERY nice wheels. The machine work in them is very clean and the weight system they provide is a very slick feature. I'm a bit biased on the wheel thing though,I'm proud of my 1911 bead locks. Adding weight is easy with stick on weights. Right now I'm running no added weight and like it very well. | |
05-23-2009, 08:30 PM | #26 |
05-23-2009, 08:34 PM | #27 | |
thanks for the replys to my many questions. now i can go to sleep. there is just so much to this hobby to learn. some times i get off track trying to figure out one aspect of the hobby. which leads to another aspect and so on and so forth. at least now i have the tire issue out of the way. thanks very much for your time and patience. | |
05-24-2009, 10:26 PM | #28 | |
Quarry Creeper Join Date: Sep 2008 Location: Castro Valley
05-27-2009, 04:50 PM | #29 |
I joined the Band! Join Date: May 2009 Location: anaheim
| I was thinking of trying this but dont run beadlocks and dont really want to soak them. Can I just spray on the simple green and scrub?
05-27-2009, 04:51 PM | #30 | |
05-27-2009, 06:11 PM | #31 |
I'm sure that it would work, you just have to be careful not to get any water or liquid inside the tire.
05-27-2009, 08:55 PM | #32 |
RCC Addict Join Date: Jun 2008 Location: Fresno
when i use paragon i usually -dab the entire tire till its shiney -when its dry i hit the tires w/ another coat then wrap it in plastic wrap to let the traction compound soak -right before i go to my crawl spot i unwrap the tires and let them air dry. w/ my rig on its back so i dont get any extra dirt or dust on the tires paragon makes the tires really sticky basically you can take a quarter drop it flat on the tire and turn it upside down w/o the quarter falling off you can also use the wd40 method in where you soak the tires in wd40 for between a day and ahalf to 3 days. i usually dont use this method because it can get pretty messy. btw i personally dont wear down the tire treads on purpose i like my tread sharp |
05-28-2009, 10:46 AM | #33 |
Newbie Join Date: May 2009 Location: US
| Hah, I just got into this rock crawling thing, coming from many years with helicopters. I am thinking about going back, far simpler. For one thing, hop up parts work without fabricating. The heli kits themselves are in the ballpark for beginning, they don't need 90% replaced right off the bat to go fly.
05-28-2009, 12:59 PM | #34 |
Rock Crawler Join Date: Jun 2008 Location: Naples
| Get an empty 'Bingo Marker', fill with Simple green and dab over the treads till completely covered, set for a couple minutes then wipe off with a damp cloth/sponge, rinse the cloth/sponge after each tire.
05-28-2009, 02:13 PM | #35 |
Rock Crawler Join Date: Jul 2008 Location: Port Angeles
| I'm with you...just go out drive your tires will take care of themselves. |
05-28-2009, 05:43 PM | #36 | |
Same here Tim, but I will roast them a good 15-20 seconds on a rock to warm them up on cooler days, right before I set my truck down at the start gate. | |
05-28-2009, 06:52 PM | #37 |
05-28-2009, 07:08 PM | #38 |
05-29-2009, 12:03 PM | #39 | |
05-29-2009, 12:04 PM | #40 |
| A bingo marker? haha not sure where to get one of those. Thanks for the reply though
