Go Back   RCCrawler Forums > RCCrawler General Tech > Tires and Wheels
Thread: Maximizer offset & backspacing
Old 11-15-2005, 01:14 PM   #1
varcor.org
swell searcher's Avatar
Default Maximizer offset & backspacing
What is the offset and backspacing for the standard Maximizer Beadlocks? I got a set coming from NitroRC Ed and wanted to see which adaptors to buy for my clod.
TIA, Randy
swell searcher is offline   Reply With Quote
Old 11-15-2005, 01:49 PM   #2
MODERATOR™
EeePee's Avatar
Just like a normal Maxx wheel. So you'll want Heydco, or Thunder tech, or something that adds a little width.
I just put mine on the TXT and with Thunder Tech adapters and Mashers the overall width is 13.5 inches. Clod will be the same.
EeePee is offline   Reply With Quote
Old 11-15-2005, 05:15 PM   #3
I have a clod, w/RCGUY wheel adapters and used Maximizer X75 beadlocks. Makes the width about 13+/- inches
lvl1 is offline   Reply With Quote
Old 11-16-2005, 09:37 AM   #4
Madcratebuilder's Avatar
TIA, Randy
The standrad backspace is 42mm (1 21/32)
X75 is 23mm (29/32)
Madcratebuilder is offline   Reply With Quote
Old 11-16-2005, 09:59 AM   #5
do you think that x75s with heydco adapters and lsts will be to wide?
niggle is offline   Reply With Quote
Old 11-16-2005, 02:48 PM   #6
MODERATOR™
EeePee's Avatar
Not too wide with the tall LSTs, but the steering servo will be working pretty hard to turn the tires.
Old 11-16-2005, 02:55 PM   #7
varcor.org
thanks for the replies.
Old 11-20-2005, 01:25 PM   #8
yea I have some wideners on my clod with 5 hole maximizers. I dont know which wideners but they look like black derlin ones. If I mounted the wheels normally I found that it scrubbed the links, so I had to flip the center part of the wheel but it makes it too wide. I still need to find some different adapters or something.
Super Mario is offline   Reply With Quote
