![]() | #1 |
Newbie Join Date: Oct 2004
Do I need a adapter to put them on? LMK, I want to put them on my basher. Thanks ![]() |
![]() | #2 |
I wanna be Dave Join Date: Jun 2004 Location: San Jose
we kinda need more info, like social secruity # and so forth.
![]() | #3 |
LOL, Sorry.. Its gonna go on Clod Axels... The truck will have a home made chassis. Let me know... Thanks! ![]() |
![]() | #4 |
Rock Crawler Join Date: Jul 2004 Location: OC, Oregon
you will need adapters to run maxx wheels on a clod ttr makes some and so does inetrc |
![]() | #5 |
I'm not a clod so I'm asking. Could you run TXT wheels on clod axles? If so then you won't need adapters just some of my faux beadlocks to mount maxx tires to narrowed TXT wheels. cough(plug) cough cough.
![]() | #6 |
So the LST Rims will fit on Maxx Hex's?
![]() | #7 |
okay...the clod hex is 12mm..and the maxx,lst,mgt,savage..almost everythink nowdays is 14mm hex...txt wheels i think u need to buy the longer axle shafts for the knuckles because the txt has a different hub...u will need adapters to run maxx (14mm) hex....or if you dont car about looks you can go redneck style and bolt the wheels the the hub peice i run these cheap but not the best http://www.thundertechracing.com/adapters.htm |
![]() | #8 |
Thanks, I will order some up so I can get the LST's... ![]() |
![]() | #9 |
Quarry Creeper Join Date: Aug 2004 Location: HP lounge
I got those TTR ones, they're good I guess, but the part that replaces the locknut likes to loosen because it doesn't have any nylon to keep from sliding off. However, it is pretty cool because I can use those same adapters and run Clod wheels and tires on my Pede!
![]() | #10 |
Guest
Posts: n/a
Use some blue lock tight
