rover question I just got some rovers and was wondering if I can use my proline memory foam out of my hammer. The hammers are way smaller so any help would be much appreciated. Is the rover foam any good. |
I had good luck with the stock Rover foams. Smaller foams will make them too soft though I think. |
i also agree stock rover foams work great"thumbsup" |
i have had my rovers since they first came out and loved even with the rover foam very soft but not to much just perfect"thumbsup" |
thanks for the help |
I too have great luck with the stock foams...maybe just trim them so there not so wide. |
The stock foam works ok, but doesn't fill out the tire because its too short and the lugs fold over and don't get you anywhere I went with a harder Panther standard foam (F-400 I think) and its perfect and I got a lot more hight out of the tire |
if you can swing the $25, i would HIGHLY suggest Nova Ark's 5.5 Double Duece foams. they are well made, and so far, they have a nice feel inside of my Rovers, and i haven't even munkeyed around with tuning them yet. they give a nice firmer sidewall, yet provide a nice "squishy" outer tread surface. "thumbsup" |
i did have the stock foams in my rovers but they were too soft so i upgraded to proline 2 stage foams, they seem to be working very well for me |
The ProLine 2-stage foams work good in a warmer climate, if the temperature changes much, the foams will get harder if it gets cooler. The Crawler Innovations foams work really nice n the rovers also. The stock foams work really well but are a bit small for the tires. |
Stay with the stocker Maybe throw some tuning disks in front. in rear The Crawler Innovations foams work really Eddie foams rock!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! |
i took some of the proline memory foams and sliced them in half. i made a long foam that was half as thick and wrapped it around the stock rover foams. i used some headliner spray glue to hold them together that way my foams are almost 6 inches tall with a memory foam outer. i have used them with 2 sets of rovers and now have them in some sedonas. |
the Nove foams are the best I've tried in the Rovers and the Sedonas. good mixed and for me are better than the stock foams - which aren't exactly rubbish mind. |
thanks for the feed back it looks like I'm ordering some novas on monday"thumbsup" |
I found the more you run the Rovers and the Nova foams the better they get. it's a great excuse to get out there and play to :ror: |
