06-30-2010, 03:31 PM | #1 |
Tire&Foam Extraordinaire Join Date: Jun 2007 Location: C.I. Compound, Tyler, Texas
| Robras! 5 7/8 tall cut n shut tires by Crawler Innovations
Here is a custom set of Robras I made for a RCC forum member. They are constructed using 6 Panther Cobras and 8 white dot Hot Bodies Rovers side walls. These come in at 5 7/8 tall when constructed like this. This particular set is made with white dot super soft Panther Cobras in front and red dot soft compound Panther Cobras in the rear. The foams are standard 5.5 tall foams narrowed to 2 inch in the front and 1 13/16 in the rear. When mounted on a 1 inch wide rim them feel very good. I included tuning rings just in case the customer needs added height from the foams. I am testing a set of these that are 5 5/8 tall and use Losi Rock Claw side walls on my 2.2 berg. I'll try and post pictures of those later. |
06-30-2010, 03:38 PM | #2 |
I wanna be Dave Join Date: Jun 2005 Location: drillin Holes for the man
Oh yeah! Those turned out nice. I will be calling you this evening about these. You gonna let me try out yours on my rig? |
06-30-2010, 04:00 PM | #3 |
RCC Addict Join Date: Dec 2007 Location: On The Lake
06-30-2010, 04:39 PM | #4 |
Rock Crawler Join Date: Jun 2009 Location: Minnesota
These look freaking sweet |
06-30-2010, 04:48 PM | #5 |
Rock Crawler Join Date: Jan 2009 Location: San Gabriel, Crawlerfornia.
OMG i want a set to bad i prob cant afford a set of theses.They are awsome |
06-30-2010, 05:55 PM | #6 |
Plz let us all know what u think of the set ur testing!
06-30-2010, 09:51 PM | #7 |
do you have a before and after pic
06-30-2010, 10:33 PM | #8 |
I wanna be Dave Join Date: Jul 2007 Location: Within The Machine,,,
holy sht eddie,,those are tits,,,i like the way they came out,,,hmmm
07-01-2010, 09:59 AM | #9 |
RCC Addict Join Date: Apr 2007 Location: Murfreesboro
Let us know how they perform in your tests! I made a set of really tall skinny Flat Irons and they folded over like crazy on 1.9 wheels. I widened the tread up a bit and put the back to 2.2 sidewalls and now they are much better. Ide like to see how these act sidehilling etc, would be nice to see some tall skinny tires that work!!! Matt |
07-07-2010, 05:20 PM | #10 |
Ok, so I'll let the cat out of the bag. These are my tires and so far with the testing I have done they hands down out perform my white rovers. I will post some pics when I get a chance and write a better review. Eddie told me he tested his set that he made for himself and also had good things to say about them. I believe the quote was "this are the best tires yet" or something like that! Perhaps he will chim in and give his thoughts. Pics in a day or 2 |
07-07-2010, 05:48 PM | #11 |
Swa-eett
07-07-2010, 05:55 PM | #12 |
I had a chance to run Eddies over the holiday weekend and I was very impressed. They ran every line that the rovers and sedonas would but with a little more ease. They side hill like nobodies business and hold there line extremely well. He should be starting on a set for me very soon. This is deffinetly a tire to have in the arsinal. |
07-07-2010, 05:58 PM | #13 | |
Ultimate RC Decals Join Date: Aug 2005 Location: San Antonio
i was doubting the side hill performance. what are your thoughts if the lug have a groove down the center of the outer lugs? | |
07-07-2010, 07:12 PM | #14 |
07-07-2010, 09:41 PM | #15 |
07-07-2010, 09:59 PM | #16 |
Yes surprisingly these tires do side hill very well. I know that the 2 differant sizes don't have the same characteristics, but I have a notch in the outer lugs on my 1.9 cobras and I don't believe that it helped or hurt the performance in any noticable way. I plan to leave the 2.2 robras just as they are for now. |
07-08-2010, 01:10 PM | #17 |
I now have three battery packs on the set I made for myself. Mine are not as tall as the ones pictured in the first post. I am using a three stage foam in the front and a dual stage foam in the rear. When the rock was dry, awesome performance. I ran two battery packs and they did everything and then some. We had rain yesterday and I went to test after the rain had passed. No good. They slipped off the line on slick rock several times. It did other things just the same, but not with the authority it did when it was dry. So I don't think this will be a good wet tire. Here are some details: Test truck: T1E Moon Buggy Berg weighing 6 pounds 2 ounce RTR Front wheels: 1" wide VP DH, fully slugged 460 hubs firm 5.5 inner, medium 5.5 inner tuning ring, soft 5.5 outer White dot super soft compound cobra tire Rear wheels: 1" wide VP SLW V4 475 hubs firm 5.5 inner, firm 5.5 inner tuning ring, 5.5 outer Red dot soft compound cobra tire As for side hilling, OMG this tire is amazing. I have to admit at first I was surprised, but after some thought, I am not. In the 1.9 cut n shut size, the 1.9 rover and 1.9 cobra are nearly the same in terms of performance. I feel the 1.9 cobra side hills better than the rover, but sometimes I find the 1.9 rover climbs better on certain rock. So it would make sense that the results would be the same in the 2.2 size. Although a lot more testing is needed, preliminary results are pretty astonishing. It works better than I could have expected and the tall tire height helps the diff clearance ssooo mmuuch. It's a very fun tire to drive. The tire is fairly skinny and with the 460 hubs it never gets into the springs. It is very easy to hang a tire on a ledge and then just have it pull you right up and over. One thing I am eager to see is if it continues to have the crazy forward traction after the edge is worn off. In the 1.9 size, I find they just keeping working as they wear. Sometimes in the Super size Plowboy once the edge is gone they don't work as well. So time will tell as the tire wears. Another thing I really like is no side lugs. It seems like this tire recovers easily when in a precarious position. I definitely need to get this tire into competition and into the hands of some more capable drivers. It seems like it works that good on dry rock. |
07-08-2010, 04:15 PM | #18 |
RCC Addict Join Date: Dec 2007 Location: Rochester Hills
I'm definitely interested, I would also like to have ya narrow my dirty Harry's. Nice work once again Later, Farmer |
07-08-2010, 04:21 PM | #19 | |
Thanks Farmer. Here is all the info on narrowing bead locks: Custom bead lock machining offered by Crawler Innovations | |
07-08-2010, 05:02 PM | #20 |
OK, here are some pictures of the set I made mounted on my son's berg. They are not that tall when mounted up, but keep in mind I was aiming for a 5 5/8 tall tire. Notice the little shreds of rubber already hanging off the front tires with only four battery packs on the tires. The super soft Panther compound is just that - super soft. A good amount of diff clearance for a berg. Very high belly clearance. This truck could stand to be lowered a bit with these tall tires. Just under 5 5/8 fully slugged. Right at 5 5/8 in the rear. |
