07-08-2010, 09:22 AM | #41 |
Rockin' in Reno Join Date: Mar 2010 Location: Reno
| I was having problems as well. What I figured out was that the bead was folding back under instead of going into the slot. I found that if I pushed the sides of the tires all the way down past the rim so that the bead was being bent out a little bit towards the inside of the wheel, then put the bead lock on, it would force the bead down into the slot that way, and that solved the problem.
07-08-2010, 09:27 AM | #42 |
Y-Town Crawlers Join Date: Oct 2005 Location: Not Hesperia
Mine were tough to mount on DH's as well, you just have to take your time and make sure that the bead is fully seated in the groove before you tighten down all the bolts. Interestingly enough, the same set of tires mounted very easily on SLW's, even with overstuffed foams. |
07-08-2010, 09:33 AM | #43 |
I wanna be Dave Join Date: Nov 2009 Location: Chico now
Finally succeeded.
07-08-2010, 10:42 AM | #44 | |
Quarry Creeper Join Date: Sep 2006 Location: Phoenix
But my tests for grip will be objective because there are, like we all have, some known climbs where some tires spin and chew and never hook up, others spin and chew and eventually hook up, while others walk right up. That's where I'll be testing. I've already seen in person, the amazing smoothness of digging and burning with these tires. The big-lug tires will get to bouncing during a dig as the lugs flex and rebound. These little lugs just keep a smooth, steady, bounce-free spin during a dig or a rear burn. So far so good. | |
07-08-2010, 06:30 PM | #45 |
Game on suckers. |
07-08-2010, 07:43 PM | #46 |
Rock Stacker Join Date: Jan 2008 Location: Lake Almanor
they were worth the pain to put on for me.
07-08-2010, 10:44 PM | #47 |
Let's see some pics of these tires on the rocks... Is everyone having too much fun pulling off new lines that they forgot to bring their cameras |
07-09-2010, 12:14 AM | #48 | |
RCC Addict Join Date: Jun 2009 Location: California
with these bad boys. Front: 1" DH Pro Comps channeled. full wrap with four bullets, each front weight in at 15oz. Huge front dual stage Nova 5.5 inner foam with the Dual stage pro- line outer wrapped around. The foam comes in at around 6" tall, very full claw but with a nice sweet spot in the middle to help it climb.... Rear: 1" SLW, about a half wrap, each rear weight in at 8oz...Running a F400 in rears. Went out today and crawled the same spot as always....I try a particular side hill gap that I have only completed one time. Today, walked threw it like six times. I'm so amazed how the claws perform with a full foam setup...Amazing, I'm sold on the Boss Claws...The red compound looks brand new still after three runs! A softer setup version would be Losi Pinks in rear with Nova 5.5 front...But I much prefer the oversize front dual stage and F400's rear Quick cell pic. Last edited by fa1rch1ld; 07-09-2010 at 01:01 AM. | |
07-09-2010, 04:35 AM | #49 |
Quarry Creeper Join Date: Dec 2009 Location: armpitts, CA
i like them. it was whole different way of driving. i was tipping over more than usuall. i just i was so used to the wide footprint of the sedonas and the way they collapsed. i did mount them in a rush before tonight comp but i just used the stock foam wich wernt too bad for me since i had a wrap of lead on the inside wich filled in the air gap. also i lowerd the rig. now it was performing, it amazed me what things it was able climb. being that my first run was a comp i did pretty well and even better afterwards free crawl. i borrowed the tires from a buddy, hopfully i wont have to give them back. JK billy |
07-09-2010, 03:31 PM | #50 |
Quarry Creeper Join Date: Dec 2008 Location: San Diego
there the old cut and shut but here are pic of them doing work |
07-09-2010, 04:43 PM | #51 |
AKA 2G's Join Date: Feb 2006 Location: Where the wind blow's
Im pretty happy with them so far . The stock foams were to stiff for my 5 pound rig thow. Here's some picture's of some pretty hard line's. Cant wait to see how thay do at the COl. comp next week.
07-09-2010, 04:49 PM | #52 | |
Nice pics Greg. Good luck in Colorado | |
07-09-2010, 04:58 PM | #53 |
| So that's what happen the first time i tride to order them. LOL,The second time i used a fake name and the order went threw. See you next week.
07-09-2010, 05:06 PM | #54 |
07-09-2010, 05:17 PM | #55 |
07-10-2010, 02:43 PM | #56 |
Pebble Pounder Join Date: Feb 2009 Location: Highlands Ranch, CO
Great info in here. I've got a question on venting the tires. Is everyone adding vent holes similar to what you ran with other tires when using these on DHs and SLWs? Thanks |
07-10-2010, 06:12 PM | #57 |
07-10-2010, 08:14 PM | #58 |
07-10-2010, 10:31 PM | #59 |
Quarry Creeper Join Date: Sep 2008 Location: Oakley
Thought I'd throw this out there...... First set of foams I ran in these today was Nova's 5.5 with the inner foam cut down to 1.75". I will be getting some different inner foams to try different combos. Tires seem to do best when stuffed full with a small soft contact patch. Should add that I'm running MSD wheels and the total weight is 14oz front and 10oz rear. |
07-11-2010, 01:03 AM | #60 |
Quarry Creeper Join Date: May 2010 Location: Longmont, CO
| I bet these tires are going to do great out here on the red rock. Its suppose to be in the mid 90's all weekend if that helps prepare. See you there |
