07-14-2010, 05:17 PM | #81 |
Rock Crawler Join Date: Jul 2007 Location: E LEE, NV
Well took them to a local crawl spot and these tires wouldn't hook up for nothing The side hilled awesome but I couldn't get them to dig and grab or climb very well. Kinda made me mad after fiighting with the beads for a long time only to find out my foams are not right. Think they were maybe too stiff? Running novas front and back rig is like 4.7 lbs lcc |
07-14-2010, 05:32 PM | #82 | |
Y-Town Crawlers Join Date: Oct 2005 Location: Not Hesperia
07-14-2010, 05:42 PM | #83 |
maybe i just need some weight then lol ok put it on the scale and its about five pounds i dont have any weights in the rear wheels and im running stock losi wheels
07-14-2010, 05:50 PM | #84 | |
Is that for one foam or all 4 foams, it doesn't say on the description, also what would be a good non memory foam for cold weather, i'm assuming some nova DD | |
07-14-2010, 08:14 PM | #85 |
RCC Addict Join Date: Jun 2009 Location: California
So the front mystery foam is reviled....ordered mine up...Going to try them on my .7's |
07-14-2010, 10:25 PM | #86 |
Rock Crawler Join Date: Oct 2008 Location: Sandy, OR
| You definitely need to add some weight to the wheels, or go with a super soft foam setup, one or the other.
07-14-2010, 11:35 PM | #87 |
i have like three and a half oz per wheel in the front what is everyone else running? what would be better a light rig with soft foams or a heavy one with the foams im running when using the lcc? my axial liked to be light
07-14-2010, 11:49 PM | #88 | |
Quarry Creeper Join Date: May 2010 Location: Longmont, CO
Alot of people run 2-3x what your running and are happy with it. Last edited by Fattymojo; 07-14-2010 at 11:53 PM. | |
07-14-2010, 11:56 PM | #89 |
Quarry Creeper Join Date: Dec 2008 Location: Ramona
OO I cant wait for mine to come, along with my ESC back from Horizon as well.. I ordered me set of SLW, and 3 set of the adapters.. I hope there right? and boss claws (red).. but im leaving the foams optional for now. |
07-15-2010, 12:02 AM | #90 |
Rock Crawler Join Date: Nov 2008 Location: lakeside
most people put the front wheel tire and foam weight around 13 to 16oz in the front. |
07-15-2010, 02:12 AM | #91 |
I am confused about the hex hub for the SLW.. which size would be recommend? the place I am ordering from only has 600, 350, 225 in stock.
07-15-2010, 02:34 AM | #92 |
losi 600 get two pairs of them and the one pair of losi 475.
07-15-2010, 07:16 AM | #93 |
07-15-2010, 07:26 AM | #94 |
Rock Crawler Join Date: Dec 2008 Location: With the ATL Crawlers
My first couple of packs through these were pretty good, some slipping on lines I pull fine w/ Comp Claws, but overall I was pleased. Mostly On the extra clearance gained. They dig/burn'd great. Running DH's w/ 3 sluggs, stock pink-ish foams, about 13.5oz ea. Rears Slw's 1in, stock foams, about 7oz ea. Went out yesterday for a couple more packs, on totally new rock. Added all six sluggs to ea. front wheel, now 15.5oz. Added .5oz to ea. rear, 8oz. The Lcc was pulling crazy stupid lines. Very impressed! My rig is slightly less than 6lbs, 5.92lbs to be exact. All on stock pink foams. I'd say start there. I've got PL over sized foams, I'm thinking about wrapping them over some stock gray losi claws foams |
07-15-2010, 07:37 AM | #95 |
DHs with stock pink foam in front SLW 1" in rear with sedona foam around some proline inner foam. The fronts are fatter than the rear. Its working but the front is hard and doesn't like digging on ledges when it's up and light. |
07-15-2010, 09:44 AM | #96 | |
They are a little softer then what I normally run in a DH procomp wheel, however on a lighter rig they should work very well. My favorite setup so far with these memory foams has been on the .7" or 1" SLW's with 2 wraps of weights inside the tire for foam support. | |
07-15-2010, 10:58 AM | #97 |
Why do you fill the silvers work better in higher temps and on higher traction rocks? B/c the red compound is too soft w/ higher temps? I noticed my red's slipping w/ the temp outside around 96+
07-15-2010, 11:03 AM | #98 |
| That's correct. On some rock, the red compound starts to be too soft and slick when temperatures are 95+ It really depends on the type of rock too. My reds hook up better on smooth rock no matter what, but my silvers seem better on granite when its really hot.
07-15-2010, 11:10 AM | #99 |
What your choice for foams whenever the weather cools down a bit. Say below 65? What's the cut off temp for mem. foams?
07-15-2010, 11:55 AM | #100 |
I've used these memory foams down to around 60-65* without any problems. They do start to stiffen up, but they aren't as bad as some memory foams out there. When its really cold, I've been switching to a dual-stage foam or even a standard rock claw foam that has been trimmed. |
