Go Back   RCCrawler.com Bulletin Board > RCCrawler General Tech > Tires and Wheels
Thread: bft or txt-1 tires
Old 04-02-2004, 03:09 PM   #1
200th engineering
spookyseven's Avatar
Default bft or txt-1 tires
does anyone have a pic of the two to compare the size??
if i did get one of the two, which rims are suggested to get to put them on, i would like them to fit on a e-maxx, and should i/how would i cut the rims
thanx
spookyseven is online now   Reply With Quote
Old 04-03-2004, 06:04 PM   #2
Colt Python/SR9c
TwistedCreations's Avatar
Default Re: bft or txt-1 tires
dont have pics, but my BFT tires measure just shy of 7" tall ( like 6 7/8")and right about 3.5" wide on my stock Maxx rims...i was gonna narrow mine, but just slapped them on...don't know if i will even narrow my rims at all since the tire buldges out about a 1/2" or so on both sides of the rims
TwistedCreations is offline   Reply With Quote
Old 04-27-2004, 02:08 PM   #3
200th engineering
ok, do u kno were i can get some online?
Old 05-14-2004, 10:30 PM   #4
www.stormerhobbies.com And narrow them, they are soooo nice with ALL that sidewall sticking out.
MaxxZilla is offline   Reply With Quote
Old 05-16-2004, 12:10 AM   #5
31st place in 2006 Nats!!
toyofast's Avatar
BFT tires to the left and stock TXT's on the right
The BFT tires are a tad taller and a bit more narrow that a stock txt tire. If you're after a pure crawling tire and had to pick between a stock TXT tire and a BFT tire I'd go BFT hands down. Both will need to be modded to get more flex and better performance out of them but the BFT tire will out perform the TXT.
Here you can see a properly modded BFT tire:
Also don't be fooled by the imatation BFT tire, I've read that it doesn't have the same soft compound as the real AE BFT tire.
toyofast is offline   Reply With Quote
Old 05-16-2004, 01:30 AM   #6
toyo, that crawling site... it's beautiful... I must crawl it.
Old 05-16-2004, 12:44 PM   #7
toyofast's Avatar
Dude... should have driven out today as a group will be there around 11:30 to tear it up! I can't make it due to another pre-aranged duty via the wife Although where I'm going I might drag the half pieced back together Juggy to crawl on some rocks... yet by looking at it across the room I don't think so, half of a front axle, no motor, no reduction unit and just not ready to travel yet :(
Old 05-16-2004, 01:04 PM   #8
I too have broken rig problems... once it is running I might join you.
Old 05-18-2004, 12:41 PM   #9
does anyone know if the BFT tires will fit on a big joe rim?
ultralord is offline   Reply With Quote
Old 05-18-2004, 12:47 PM   #10
PapaGriz Yo
Grizzly4x4's Avatar
No, BFT's fit a standard Maxx, Savage, or BFT diameter wheel. Big Joe wheels are larger diameter.
Grizzly4x4 is online now   Reply With Quote
