Go Back   RCCrawler Forums > RCCrawler General Tech > Tires and Wheels
Thread: widest positive offset wheel?
Old 07-30-2010, 01:27 PM   #1
Sometimes, I make things.
crazyorigin's Avatar
Default widest positive offset wheel?
What is the widest positive offset wheel? If I am thinking backwards w/ wheel offset, I am looking for wheels to give the maximum track width. Thanks, already did a search and nothing came up.
crazyorigin is offline   Reply With Quote
Old 07-30-2010, 01:33 PM   #2
For what axle? Are wideners not an option?
JeremyH is offline   Reply With Quote
Old 07-30-2010, 01:49 PM   #3
Tire&Foam Extraordinaire
Nova's Ark's Avatar
The TLT offset was the best way to get maximum wheel offset. Basically, the hex was flush with the back of the wheel. Mayhem Engineering, MSD, Eritex and RC4WD all made wheels with that off set. You don't see it to much any more in 2.2 wheels because the axles have gotten wider and you need the wheels to come in to make the track width narrower.
Nova's Ark is offline   Reply With Quote
Old 07-30-2010, 02:01 PM   #4
~THE SCALE SHOP~
mayhem has what you need.
www.mayhemengineering.com
STANG KILLA SS is offline   Reply With Quote
Old 07-30-2010, 02:08 PM   #5
The TLT offset looks like the ticket for what I need. The axles I am putting them on are Poulsons. I may end up making some slightly wider wheel hexes for them but would like to just be able to slap on wider wheels as I need to get a set anyways. Thanks for the answers guys, I appreciate it.
Old 07-30-2010, 02:26 PM   #6
Vanquish Products now has .850 offset for here 2.2 slw's
sally1800 is offline   Reply With Quote
Old 07-30-2010, 04:24 PM   #7
Stock Berg wheels are another good and cheap option. Also a super stout wheel. I drill them out for 3m hardware tho instead of the 2mm.
Krakker is offline   Reply With Quote
Old 07-30-2010, 07:01 PM   #8
What he said. Have them in stk.
Mayhem Eng. is offline   Reply With Quote
