Go Back   RCCrawler Forums > RCCrawler General Tech > Tires and Wheels
Thread: Who still using PL Hammer tires?
Old 08-10-2010, 06:55 PM   #1
Default Who still using PL Hammer tires?
I have mounted 2.2" Pro-Line Hammer tires on my SCX10 Dingo truck and added extra weight to the wheels. I really like them. I see many people running newest tires, are the new tires really better? So far mines are doing really well.
Sylvain is offline   Reply With Quote
Old 08-10-2010, 08:09 PM   #2
i really like my hammers
PhantomRS10 is offline   Reply With Quote
Old 08-10-2010, 08:51 PM   #3
Like my hammers much better than rock lizards but not better than rovers. Now my hammers have been cut n shut and they are on my kids mrc.
RickM is offline   Reply With Quote
Old 08-10-2010, 09:13 PM   #4
I'm rockin hammers on my creeper and winning comps with it at my lhs.
mastathug0 is offline   Reply With Quote
Old 08-10-2010, 09:38 PM   #5
Last Generation, but still awesome tires:
Proline Hammer
Proline Badland
Losi Rock Claw
In fact, I've got some Badlands on the way!
The older generation of tires doesn't perform quite as well, but fairly close.
And the real benefit is when you need a smaller 2.2 tire.
J.DUKE is offline   Reply With Quote
Old 08-12-2010, 06:39 AM   #6
Better for what??? If older tyres still do what you need them to, why change???
Sith Lord is offline   Reply With Quote
Old 08-12-2010, 11:06 AM   #7
Better for my scale truck... rock, dirt, mud...
Mines are doing very well but it doesn't me stop to look for something better if it does exist
Old 08-12-2010, 11:11 AM   #8
I thought the biggest difference was in the size. The PL Hammers are around 5 inches tall, whereas the rovers are closer to 5 1/2". On a larger truck, it would be similar to going from a 33 inch tire to a 37 inch tire. BIG difference in capability just because of the size. I love the hammers' traction, but I really wish I had the extra ground clearance. I've got panther leopards on the way for just that reason.
cwettstain is offline   Reply With Quote
Old 08-12-2010, 11:47 AM   #9
on my comp rig i had hammers and i switched to rovers, i cant believe how much better it performs now, the diff case dosent get hung up on stuff hardly at all anymore.
thomas is offline   Reply With Quote
Old 08-12-2010, 02:16 PM   #10
I still use mine on the scaler for jumping and bashing. There the light weight setup for me.
jonbo21 is offline   Reply With Quote
Old 08-12-2010, 03:25 PM   #11
I'm currently running Hammers with narrowed Panther 400 foams on my Wreckluse. I've always liked the Hammers for general use, and with the new foams I gained close to half an inch in height. I cut about 3/8" off the width of the 400's to get a narrower profile and to add some height. I haven't tried the new setup yet, but I should see a major improvement in grip and sidehill ability.
TrailDawg362 is offline   Reply With Quote
Old 08-13-2010, 08:48 AM   #12
im running hammers on my rig and they do very well
school boy is offline   Reply With Quote
Old 09-02-2010, 05:26 PM   #13
I used Hammers for a long time. I recently went to Chisels and I really miss my Hammers, LOL! The taller Chisels changed the way my rig performs. I think I'm gonna mount the Hammers back on some old Axial beadlocks and keep them with me when I crawl.
chops1sc is offline   Reply With Quote
Old 09-03-2010, 08:57 AM   #14
Default Please make a 5.5" G8 Hammer!!
Hammers are my favorite tire of that generation of crawler tires. Not a fan of the Chisel. I wish PL would make a 5.5" G8 Hammer. Offer them with 2-stage foam, oversize mem foam or oversize standard foams in the package. I'd buy a few sets.
John82601 is offline   Reply With Quote
Old 09-03-2010, 02:31 PM   #15
Well here's my deal....I like my hammers because they are short. I run full droop and I was able to make climbs others (including some moa's) couldnt make. As soon as I put the taller tires on it went to the crapper. However, I am in the process of fully overhauling my rig as we speak so maybe I can make the taller tires work.
BUT, I would buy a set of tall Hammers. Hell I might try making some!
Old 09-03-2010, 11:20 PM   #16
Jus
My wifes ARTR Axial is still sporting the hammers that came on it.. I love the look of these tires.. I've got a great low COG setup on that rig and still using the stock memory foams and it sidehills incredibly well.. Very stable. The G8 compound is supposed to be very good right? If the hammers are made in this compound I might actrually try some.. I drive a droop rig so I don't care about ground clearance the newer/taller tires give you, I like to keep it low.
Jus is offline   Reply With Quote
Old 09-04-2010, 08:12 AM   #17
My son is running them on his 2.2 Sportsman rig.
Tomy is offline   Reply With Quote
Old 09-04-2010, 09:28 AM   #18
Default I use them on my scaler they work great.
MR.VERTICAL is offline   Reply With Quote
Old 09-05-2010, 06:26 PM   #19
Amen! I run droop as well. The taller chisels are kicking my tail right now after running hammers for 2 years.
They do offer hammers in G8...
http://www3.towerhobbies.com/cgi-bin...?&I=LXWJW3&P=7
Old 09-05-2010, 10:08 PM   #20
well i am running the stock pl hammers on my new out of the box axial ax10 scorpion RTR....they are doing good and now that i have altered them with my dremel they climb even better......i cut up the foams and added weights to the wheels before mounting the rubber back on
scorpion_ax is offline   Reply With Quote
