09-04-2010, 11:45 AM | #1 |
| Best cleaner for tires
Whats the best cleaner for tires that will also help keep dirt/dust off of them. I've heard good stuff about simple green, is there anything else. Most of our course require you to run and/or dig in dirt and it makes my boss claws no better than any other tire.
09-04-2010, 12:22 PM | #2 |
I wanna be Dave Join Date: Apr 2007 Location: Arlington, Washington
In offroad, we pretty much all use warm water with simple green added to it with an old scrub brush....seems to help get the crud off good and conditions the tires at the same time. I would imagine it would work with crawler tires just as well.... A big thing is to make sure you get the tires fully dry.....water likes to seep, so make sure to get it good and dry. Later EddieO |
09-04-2010, 12:41 PM | #3 |
RCC Addict Join Date: Oct 2009 Location: San Francisco
I agree with Eddie. Here's what I do (yea its labor intensive but it works for dirty tires ): Pre-rinse the tires and rub off any clumps of mud or whatever "easily removed dirt" comes off. Apply some foaming soap, nothing fancy here. If its cheap and it foams it works (regular works but takes longer to get it off since its so concentrated) Spray on 100% Simple Green (if not very dirty) and let it soak while you do the others (eeh 5-10 mins, depends on how patient you are) If the tires are real dirty, mix up 50/50 Simple Green and water and let it soak. Really works good, you will die at how dirty the water can get if you do this method When done just scrub again and fling dry. I like to stick mine in our gas oven over night and it dries them out nicely. I have found this to be "sort of" labor intensive but man the results are incredible when you pull them out. Nice and STICKY |
09-04-2010, 12:51 PM | #4 |
Rock Stacker Join Date: Aug 2010 Location: Minneola, Florida
I use warm water and let them soak for a while i dawn dish soap the scrub the with a soft bristle brush, dont you a metal bristle brush because it will scratch up your tires!
09-04-2010, 03:33 PM | #5 | |
Also i read somewhere about wd-40, how well does that work | |
09-04-2010, 03:35 PM | #6 |
Just got with a brush and simple green.....wd40 doesn't clean them any better. Many feel it softens them up.....but there are better ways to soften your tires. Later EddieO |
09-04-2010, 04:06 PM | #7 |
boss claws are super soft rubber, I'll try and pick up some simple green sometime
09-04-2010, 04:21 PM | #8 |
id wash well (make it look black and shiney, and can be on the wheel) spray with simple green, let dry, then wash again with water and let dry again
09-04-2010, 06:14 PM | #9 |
| Yep you can do it like that. I do it all the time since I hate removing my tires from my rims (RC4WD ones are a pain to get a bead set and if you stare at em wrong they loose it again.) But yeah as long as the foams don't get wet, its perfectly fine |
09-05-2010, 03:08 AM | #10 |
Newbie Join Date: Aug 2010 Location: surprise
Damn good idea. I have been afraid to put soap on mine but simple green might be good
09-05-2010, 09:14 AM | #11 |
Rock Crawler Join Date: Jan 2006 Location: Vacaville, CA
just wash them with warm water and whatever dish soap you have right now. Most dish soaps have a anti grease type formula so they wont leave them all filmy. I've used simple green and it works but I feel that the simple green leaves a film that i just wash off with dish soap. |
09-05-2010, 10:15 AM | #12 |
RCC Addict Join Date: May 2010 Location: So. Charleston. Wv
Nice warm soapy water, i use original dawn dish soap. best thing to clean them with
09-05-2010, 10:17 AM | #13 |
Don't get your foams wet.
09-05-2010, 06:29 PM | #14 |
Rock Crawler Join Date: May 2008 Location: Sumter, SC
Simple Green works best for cleaning, but I dont think there is anything that will prevent them from getting dirty. And dont get your foams wet. |
09-05-2010, 08:34 PM | #15 |
just wondering, why is it mentioned don't get foams wet,
09-05-2010, 08:40 PM | #16 |
Mold... tropical fish... flys No its not good since the foam is a LOT more likely to tear... don't ask how I know |
09-06-2010, 07:35 AM | #17 |
Yeah water will shorten the life of foams.
