![]() | #1 |
Tire&Foam Extraordinaire ![]() Join Date: Jun 2007 Location: C.I. Compound, Tyler, Texas
I was asked by a fellow forum member to make these tires for his Super. It takes six Hot Bodies Sedonas and Four Pro-Line Moab XL's to make this set of four. The Dual Stage foams are a new Super Size dual stage foams several of the Team C.I. drivers came up with. The inner foam is thicker and I have several different outer foams depending on the tire height. The tires are all butt jointed with no over laps. On to the pictures; ![]() ![]() ![]() ![]() |
![]() | #2 |
Looking good Eddie!
![]() | #3 |
Rock Crawler Join Date: Oct 2009 Location: SO CAL
looks real bitchin. how do you glue your seams? just put the ic2000 on to the parts where they will make butt joints? or do you tack and run the glue over the whole seam?
![]() | #4 |
| ![]() Thanks Jeremy ![]() I use a two part process myself. I use a thin CA for the actual joint and then go back over all seams with IC 2000. |
![]() | #5 |
nice. the first set of haters I made I used aka tire glue for the butt joints, and then that tore apart in spots it must have been thin in. and after learned about ic2000 so I went over the whole inside seam with it. seems to be holding up so far!
![]() | #6 |
Quarry Creeper Join Date: Apr 2008 Location: San Diego
Was this a one time thing or would you make more? How much? |
![]() | #7 |
| ![]() This is a service I offer as a vendor here on RCCrawler. You can PM here on RCC or send me a direct email to: novasark@crawlerinnovations.com |
![]() | #8 |
I wanna be Dave Join Date: Aug 2008 Location: Having fun again...
![]() | #9 | |
MODERATOR™ ![]() Join Date: Jul 2004 Location: Ohio
| ![]() Quote:
![]() Last edited by EeePee; 09-24-2010 at 06:41 PM. | |
![]() | #10 |
killer! ![]() since every custom tire has a catchy name on here seems like, the name of this tire should be "bitch slappers" |
![]() | #11 |
![]() | #12 |
Hateraide ![]() Join Date: Dec 2008 Location: Mission BC
![]() | #13 |
Rock Crawler Join Date: Feb 2009 Location: Chandler, AZ
you should be a surgeon. ![]() |
![]() | #14 |
Rock Crawler Join Date: Jul 2009 Location: boise
damn! i can only see one tiny seam! looks awesome, good job ![]() |
![]() | #15 |
RCC Addict Join Date: Nov 2008 Location: Santa Fe, NM
WOW those look really clean!! ![]() |
![]() | #16 |
Quarry Creeper Join Date: Oct 2009 Location: Reno
Wow, sexy tires!! What width wheels are they going to mount on?
![]() | #17 | |
DOOH!!! Join Date: Feb 2007 Location: AZ
| ![]() Quote:
![]() Loaded up they sit at 2.75" wide from sidewall lug to sidewall lug, there is a slight pooch in the sidewall from stretching them over the larger diameter rims. I believe if you were to narrow these rims even more they would sit flush and roll out nicely to the tread. Foams are feeling great Eddie, wish it was ready to DRIVE!!! ![]() ![]() ![]() ![]() | |
![]() | #18 |
Rock Crawler Join Date: Jan 2007 Location: Viroqua
All I can say is one word, SICK!!!!!! looking forward to your build.
![]() | #19 |
Nice work on those beadlocks!!!
![]() | #20 |
The beadlocks are sweet! Do you have more photos of them before assembly? Do they really hold?!
