11-30-2010, 10:29 AM | #1 |
Pebble Pounder Join Date: Dec 2009 Location: Ottawa
| tires ??
I was wondering if anyone tried punching holes in their tires ? Even though there are some holes in the wheels I`d think putting a few holes in the tires would allow them to grab the rock better . I have an extra set of stock LCC tires I might try . If you run in water then this would be a bad idea . |
11-30-2010, 11:32 AM | #2 |
Lots of people put a couple small holes in their tires to vent the air. Cutting holes in the carcass for any other reason seems like a waste. I don't see any benefit to it really, what would you be trying to achieve? Are you trying to soften up the carcass? trying to make it conform better? These all seem like things you should do with your foam tuning.
11-30-2010, 12:03 PM | #3 |
I wanna be Dave Join Date: Jan 2008 Location: GrandRapids, MILITIAGAN
I think you will have better luck wiht this in the tire section.
11-30-2010, 02:22 PM | #4 | |
11-30-2010, 02:46 PM | #5 |
11-30-2010, 02:51 PM | #6 |
I use a leather punch tool that works great and fast .
11-30-2010, 06:25 PM | #7 |
Quarry Creeper Join Date: Oct 2006 Location: kansas city
The real advantage to putting the hole in the tire is for running in water. It will drain out with the hole in the tire and will not if its in the rim. Randy |
12-01-2010, 01:27 PM | #8 | |
Quarry Creeper Join Date: Feb 2010 Location: Nevada City, CA
As stated above, after you run in the water, you just pick your rig up and spin the tires by throttle real quick and it will nearly pump all the water out of the tires. Works pretty good | |
