Go Back   RCCrawler Forums > RCCrawler General Tech > Tires and Wheels
Thread: 2.2 wheel/tire help
Old 06-01-2011, 07:24 PM   #1
Default 2.2 wheel/tire help
I wanted to put 2.2's on my ARTR AX10. I can't find good info anywhere laying it out.
I think i'ven decided on the axial ripsaws. I think I need 2.2 rims (want beadlocks) and new foams. Any recommendations on what weights and how much?
Will there be any fitment issues? Thanks...
roadracin is offline   Reply With Quote
Old 06-01-2011, 08:10 PM   #2
You should get chisle g8 2.2 tires i have had them on my scx10 for a long time and i love them I PUT A FEW OUNCES IN THEM LIKE TWO
axialdude1 is offline   Reply With Quote
Old 06-01-2011, 08:23 PM   #3
Suck it up!
Duuuuuuuude's Avatar
If you have an AX10, it should have 2.2 wheels on it already. The Ripsaws seem to be a good tire so far...weights will be a preference thing. A good starting point is 8 oz in the fronts, 4 oz in the rears, then add or remove as needed.
Punctuate much?
Duuuuuuuude is offline   Reply With Quote
Old 06-01-2011, 08:28 PM   #4
i put 4 ounces in front and havent put any in back because all i do is crawl
Old 06-01-2011, 08:30 PM   #5
Suck it up!
But you just said you only used 2 ounces...
I've got 10 in each front and 4 in each rear and all I do is crawl too...
Old 06-01-2011, 09:09 PM   #6
This my 2cents worth if you can afford , vanquish dh comps on front and slw on the back nova foams all round and HB sedonas or rovers , this is my opinion but do look at alloy rims, hope this helps a little
Cheers mate
RockMafia is offline   Reply With Quote
