12-02-2004, 02:28 PM | #1 |
Newbie Join Date: Nov 2004 Location: CLEVELAND,OH
| Tire Weights?
When you put the BB's or shot in the tires is it better to put them in loose or in a bag? Thanks Rob |
12-02-2004, 02:35 PM | #2 |
Pebble Pounder Join Date: Nov 2004 Location: Ohio
| Re: Tire Weights?
Hey, im in Ohio too! I would think it would get really anoying to hear the BB's rattling around so I would put them in a bag. Hope this helps!!
12-02-2004, 02:36 PM | #3 |
Diggin' the new SCX10 II! Join Date: Mar 2004 Location: Norcal
| Re: Tire Weights?
I think you want them loose in the tire so they can roll around easily.
12-02-2004, 02:38 PM | #4 |
Rock Crawler Join Date: Jun 2004 Location: SW, Connecticut
| Re: Tire Weights?
Badger is right, they won't roll well if they are in a bag. My steel balls don't make any annoying sounds when they rattle so plastic BB's should be even quieter. |
12-02-2004, 02:42 PM | #5 | |
| Re: Tire Weights? Quote:
12-02-2004, 02:54 PM | #6 |
| Re: Tire Weights?
12-03-2004, 08:02 AM | #7 |
| Re: Tire Weights?
I am not running any foam. If that matters.
12-06-2004, 04:30 PM | #8 |
Guest
Posts: n/a
| Re: Tire Weights?
I was going to go BBs but found that small lead fishing weights were cheaper and heavier. I'm pretty sure that they are quieter as well (more of a thudding together than a clacking) |
12-06-2004, 06:43 PM | #9 | |
I wanna be Dave Join Date: Jan 2004 Location: Flagstaff, AZ
Putting them in a bag will totally defeat the idea of having them in there, if they roll around, it won't increase rotating mass. | |
12-06-2004, 07:37 PM | #10 |
Pebble Pounder Join Date: Jul 2004 Location: SOJO
| Re: Tire Weights?
try running pellets from a shot gun shell they are realy heavy and they work great (ditch the bag) -travis |
12-07-2004, 06:47 AM | #11 |
Quarry Creeper Join Date: Nov 2004 Location: Mid TN
| Re: Tire Weights?
Pellets from a shotgun shell? You do know a box of BB's is cheaper unless you happen to have loose shot laying around anyhow, right? But yea, since I reload my own shotgun shells, I had already settled on using shot since it'll be heavier.
12-07-2004, 07:30 AM | #12 |
Newbie Join Date: Feb 2004 Location: Ravenswood
| Re: Tire Weights?
I use lead shot also and it works great. The mass is much great than the BB's and seem to be a little quieter. I can't notice any noise from them when running it..The extra weight works great! Martin |
12-07-2004, 08:44 AM | #13 |
| Re: Tire Weights?
Thanks. I will be using shot instead of BB's because I have it. Thanks again for the answers. Rob |
12-07-2004, 11:36 AM | #14 |
Rock Crawler Join Date: Nov 2004 Location: Driving the Troysion Stick up the BIG BOY line!
| Re: Tire Weights?
So are you guys on running this in the front tires or in both front and rear?
12-07-2004, 12:22 PM | #15 |
| Re: Tire Weights?
I have maybe gone to extremes with 2 of my trucks, but it seems to work great!! I am running 4oz in each front tire, and 2oz in each rear tire for a total of 12oz, or 3/4 of a pound.. That is quite a bit of weight, but seeing how it is at the lowest point of the truck, it really drops the COG.. Martin |
12-07-2004, 06:46 PM | #16 |
Rock Stacker Join Date: Dec 2004 Location: Hillsboro, oregon
| Re: Tire Weights?
i just went down to alocal store and picked up like a case of 6000 bb's for like 3 bucks, put like 150 in each front wheel and works great for tire weights
12-07-2004, 07:00 PM | #17 |
The Wheels Keep Turning Join Date: Jan 2004 Location: Phoenix, Arizona
| Re: Tire Weights?
i only run weights in the front tires because i'm only using them to keep the front wheels down on inclines.
12-07-2004, 10:03 PM | #18 |
| Re: Tire Weights?
same here.
12-09-2004, 11:11 AM | #19 |
Rock Crawler Join Date: Aug 2004 Location: woods cross utah
| Re: Tire Weights?
hey kevin you runnin bb's again
12-09-2004, 05:21 PM | #20 |
RCC Addict Join Date: Dec 2004 Location: Behind the wheel of an Axial R/C
| Re: Tire Weights?
I run 8oz's in each of the front tires none in the rear
